sticky clutch pedal?
#31
My 1991 GT clutch pedal travel is about 2 inches at best before it hits the floor/bottom of the footwell. I'm a newbie to 928s. I feel like the total clutch pedal travel was much longer than 2'' when I first got the car. My other manual clutch pedal is at least 4'' or more. Can anyone help? Are 928 clutch pedal travel short? like 2 inches? And/or is there something I should adjust for more clutch pedal travel?
#32
@ClassiCarBuyer : This should be moved to the 928 forum for more on-point answers but even here in 944-land I can tell you that 2" of clutch pedal travel is incorrect. I'm sort of surprised that you're getting the throwout bearing to work with that little movement.
Good luck
Good luck
