Torque Specs
Torque Specs
Guys: I have searched the WSM for the torque spec for the 10mm bolts that hold the engine mounting arms (brackets) to the block, but I can't seem to find it. Can someone please tell me where it might be in the WSM? I have an 83 model 944. I found the spec for mounting the arms to the hydraulic mount, (8mm bolts) but not the spec for the arms to the block. Any help would be appreciated. Thanks.
dont know the spec but most of the M10 8.8 bolts elsewhere get torqued 30-33 lbft so thats what i go by.
M6 "wrist tight"
M8 10-15 depending where it is
M10 30 (33 for timing belt rollers)
M12 depends what it is.
M6 "wrist tight"
