getting an early 924-carfax anyone? and advise.
i was passing through a neighborhood on the way to drop my g/f off today and ran across an 82 924 sitting in someones backyard, all i could tell from the street was it was brown. After work today i stopped and inquired about it and found that it could be bought for 300 cash!!! Since my g/f had been saying she always wanted a 924 and this being a project, we jumped at the chance... i figure at least if its a bust i can make my money back. Tomorrow im sending a tow truck to pick up the beast, but before then, can anyone do a car fax on this vin?
WPOAAO924CN450327
the car is in florence ky.- it has the audi 2.0 n/a and the four lug wheels and the five speed trans. The interior is pretty much shot but the body and mechanicals seem to be in relatively good shape. It looks as though someone has replaced the fuel distributor and possibly the fuel pump, but i couldnt start it since the owner lost the keys and has partially taken it apart ie/ door panel, door handle, rear bumper and some misc. stuff, why i have no idea. The plan for the car is to get it into running order, do a quick overall paintjob, and make it tough enough for some fun autox action over this summer for the g/f- not necessarily need to be competitive.
1.will my turbo springs that came on my 89 n/a w/ sport suspension fit on the 82? since they have a tougher spring rate? 162 vs. 120??130???
2. will the seats from an 87 i have fit the 82???
3. does anyone have a rear bumper for an 82-?? 924 fs semi cheap since this one is broken?
4. It has 81,000 miles on it, if it runs decent, how long can it last w/ good maintenance and what do i need to replace, is it like the 944 w/ timing belts etc..sorry i didnt search too much but its late and ill be checking this at work tomorrow....TIA
anything else i need to know? dan.
WPOAAO924CN450327
xsboost90:
1) I don't believe your turbo springs will fit. The 82 924 should have the same struts as the 83-85 944. I wouln't replace the springs anyway, at least not unless you get stiffer torsion bars. Also, the 924's use a softer spring than the 944, and I believe especially the 85.5+ 944's.
2) The 87' seats should fit, however you may find spacers between the seat bracket and the seat frame; you'll want to remove them to lower the seat and buy you some more leg room, (or maybe it's the other way around, just can't remember).
3) Sorry, I'm no help here.
4) Is it 81k, or is it 181K? 81k isn't a lot of milage. 81k is not a lot of milage, and the basic engine will go for a long time with maintenence. I pulled the head off of mine at 120k and it looked good.
The timing belt is not as critical as the 944, in terms of tension; however, you should always use a tension tool on all belts, your parts will last longer, as will your belt. It's also easy to do.
The engines tend to run hot and bake the hoses and spark plug wires. Be sure to replace any suspect piece to avoid difficult to diagnose issues. Also make sure the intake boots are in good shape, and fitter properly. This is where a lot of air leaks make themselves present.
I'd replace, or have rebuilt the brake master cylinder, and the rear wheel cylinders. They may work when your first drive it, but you'll find the aged seals will suddenly fail at the wrong moment.
I'd take a key tumbler assembly to a locksmith and have him make a key. It will be cheaper than a new lockset. Or perhaps you can get a complete set off of an early 944.
Thats all I can think of for now. Good luck.
Regards,
Abdul
Regards,
Abdul
Wax On, Wax Off
Also, the 924 engine (the Audi 2.0) is a non-interference engine, so if the timing belt snaps, no prob. go buy a new one, slap it on, and you're good to go. for more information, go to www.924board.org it's similar to Rennlist as it's a free discussion board, but not nearly as popular, there are some Guru's there. Look for Vince Ponz, Lizard, or 924 RACR. they know the most (IMHO) about the cars on the board.
Here's yer carfax!
GOOD NEWS - CARFAX Certified History - Guaranteed!
This 1982 PORSCHE 924 (WP0AA0924CN450327) qualifies for the CARFAX Certified History, a guarantee worth up to $5,000 that protects you from buying a vehicle that has had any of the following problems reported to a Department of Motor Vehicles (DMV): severe damage, major odometer problems, or Lemon history.
CARFAX Talking CarTM
The story of this 1982 PORSCHE 924 (WP0AA0924CN450327) according to our interpretation of the information reported to CARFAX:
This coupe has had at least one owner. The first title for this coupe was reported to CARFAX by an Ohio DMV in 1993.
It has had no minor or moderate accidents reported to CARFAX.
It has had no DMV-reported total loss events, like a major accident, fire or flood.
It has a consistent mileage history with no indication of an odometer rollback. The last odometer reading, reported on 04/16/1999, was 78,785 miles.
It was not reported to a DMV as a Manufacturer Buyback (LEMON).
It has no recalls that still require repair.
Go to the Detailed Vehicle History for the complete history and a glossary of terms.
Report Summary
1. ACCIDENT CHECK
Total Loss Check No Severe Accidents Reported to DMV - GUARANTEED!
Other Accident Indicators No Accident Indicators Reported
2. MILEAGE ACCURACY CHECK
Truth-In-Mileage Check No Odometer Problems Reported to DMV - GUARANTEED!
Odometer Rollback Check No Potential Odometer Rollback Found
Mileage Consistency Check No Inconsistent Odometer Reading Found
3. LEMON CHECK®
No Manufacturer Buyback Reported to DMV - GUARANTEED!
4. OWNERSHIP CHECK
Number of Owners At least 1 Owner
Type of Owners Checked 9 Types of Vehicle Registrations
5. RECALL CHECK
0 Open Recall(s) Reported
6. WARRANTY CHECK
No data reported to CARFAX
DETAILED VEHICLE HISTORY 6 HISTORY RECORDS REPORTED
Tell us what you know about this vehicle
Year/Make/Model: 1982 PORSCHE 924
Body Style: COUPE
Engine: 2.0L L4 FI
Fuel: GASOLINE
Driveline: REAR WHEEL DRIVE
Manufactured in: GERMANY
Still looking for the perfect PORSCHE 924? Check out a list of them in your area.
FREE to you from CARFAX. With the CARFAX Vehicle History Report, you get all this additional information to help you make the right decision when buying or selling a used car or truck.
How safe and reliable is this 1982 PORSCHE 924?
Find out with the CARFAX Safety & Reliability Report.
Looking for other CARFAX Certified Cars like this one in your area?
Get a complete, up-to-date list of CARFAX Certified Cars
What are other CARFAX customers saying about this 1982 PORSCHE 924?
Share what you know about this vehicle. Add a CARFAX Customer Rating & Comment.
Helping your teen learn to drive?
Get safe teen driving tips and information with the CARFAX Safe Teen Drivers Program.
Total Loss Check:
GOOD NEWS! This 1982 PORSCHE 924 (WP0AA0924CN450327) has had no severe accidents or other total loss events reported to CARFAX from a Department of Motor Vehicles (DMV). This vehicle qualifies for the CARFAX Certified History, a guarantee worth up to $5,000.
No Salvage Title Reported No Loss Due To Fire Title Reported
No Junk Title Reported No Flood Damage Title Reported
No Rebuilt/Reconstructed Title Reported No Hail Damage Title Reported
No Dismantled Title Reported No Canadian Total Loss Record Reported
Other Accident Indicators:
This 1982 PORSCHE 924 (WP0AA0924CN450327) has had no accident indicators reported to CARFAX from its sources. This section checks for accidents and/or related damage reported from many public and private sources. Not all accidents are reported to CARFAX. A vehicle inspection completed by your dealer or professional mechanic is recommended.
No Salvage Auction Record Reported No Crash Test Vehicle Record Reported
No Fire Damage Record Reported No Airbag Deployment Record Reported
No Police Accident Record Reported No Damage Disclosure Record Reported
CARFAX depends on public and private sources for its accident data. Each one of these sources has different processing times. CARFAX can only report what is in our database on 24.Feb.2004 08:44:35. New data will result in a change to this report.
Not all accidents are reported to the Police. Tell us if you know of other fender benders, accidents or damage.
Accident Check FAQs:
Accident FAQs | Glossary | Register FREE Guarantee| CARFAX Help Center
Truth-In-Mileage Check:
This 1982 PORSCHE 924 (WP0AA0924CN450327) had no odometer problems reported to a DMV under the Federal Truth-In-Mileage Act. This Act requires owners to disclose odometer problems and an accurate reading when a vehicle is sold. This vehicle qualifies for the CARFAX Certified History, a guarantee worth up to $5,000.
No Not Actual Mileage Title Reported:
Title issued by DMV when the owner discloses mileage fraud or a broken odometer.
No Exceeds Mechanical Limits Title Reported:
Title issued by DMV when the owner discloses an odometer rollover.
Odometer Rollback Check:
CARFAX found no odometer rollbacks for this 1982 PORSCHE 924 (WP0AA0924CN450327). Rollbacks reported in this section originate from readings collected by a DMV or other verifiable source.
Mileage Consistency Check:
CARFAX found no inconsistent odometer readings in the mileage history of this 1982 PORSCHE 924 (WP0AA0924CN450327).
Date: Mileage:
10/15/1993 52,984
09/04/1996 60,349
10/27/1998 78,000
04/16/1999 78,785
Do you know this vehicle's current mileage? Tell us and help protect others from mileage fraud.
Mileage Accuracy Check FAQs:
Mileage Accuracy FAQs | Glossary | Register FREE Guarantee| CARFAX Help Center
GOOD NEWS! This 1982 PORSCHE 924 (WP0AA0924CN450327) has had no Manufacturer Buyback (LEMON) reported to CARFAX from a Department of Motor Vehicles (DMV). This vehicle qualifies for the CARFAX Certified History, a guarantee worth up to $5,000.
Lemon Check FAQs:
Lemon Check FAQs | Glossary | Register FREE Guarantee| CARFAX Help Center
Ownership History:
CARFAX estimates that this 1982 PORSCHE 924 (WP0AA0924CN450327) has had at least 1 owner. CARFAX analyzed this vehicle's title history and other supporting events to identify potential ownership transfers. In compliance with the U.S. privacy laws, CARFAX does not collect or report owner names or addresses.
Estimated Owners: Date: Location:
At least 1 owner No data No data
Types of Owners:
This 1982 PORSCHE 924 (WP0AA0924CN450327) was checked for 9 types of registrations.
No Personal Use Registration Reported No Fleet Registration Reported
No Lease Registration Reported No Commercial Registration Reported
No Rental Registration Reported No Non-Profit Registration Reported
No Government Registration Reported No Built to Non U.S. Standards Record Reported
No Taxi Registration Reported
Do you have information about how this vehicle was used or driven? Tell us what you know.
Ownership Check FAQs:
Ownership FAQs | Glossary | Register FREE Guarantee| CARFAX Help Center
This 1982 PORSCHE 924 (WP0AA0924CN450327) has no recalls that still require repair.
Date: Source: Description:
02/24/2004 Porsche Cars North America No recalls open for repair
Recall Check FAQs:
Recall FAQs | Glossary | Register FREE Guarantee| CARFAX Help Center
CARFAX cannot calculate the remaining coverage for this 1982 PORSCHE 924 (WP0AA0924CN450327) because no original manufacturer warranty information was reported to CARFAX by its source.
Estimated start date of warranty: 09/10/1993
Last reading reported on 04/16/1999: 78,785 miles
Today's Date: February 24, 2004
Type of Coverage: Original Warranty:
Basic No data reported to CARFAX
Drivetrain No data reported to CARFAX
Emissions No data reported to CARFAX
Corrosion No data reported to CARFAX
Transferable No data reported to CARFAX
Roadside Assistance No data reported to CARFAX
Safety belt & inflatable restraint No data reported to CARFAX
CARFAX Warranty Check provides an estimate of this vehicle's remaining warranty coverage. It does not take into account some vehicle history events. For example, major accidents resulting in Salvage or Junk titles that may void the original manufacturer warranty or ownership transfers that may decrease warranty coverage. Complete warranty coverage information is available for this vehicle at the at the PORSCHE web site.
Warranty Calculator FAQs:
Warranty FAQs | Glossary | Register FREE Guarantee| CARFAX Help Center
CARFAX searched more than 2.7 billion records from over 5,300 sources and found 6 record(s) for this 1982 PORSCHE 924 (WP0AA0924CN450327).
Date:
Mileage Reading:
Source:
General Comments:
09/10/1993 Ohio
Motor Vehicle Dept.
Xenia, OH
Title #2900042256
Title issued
10/15/1993 52,984 Ohio
Motor Vehicle Dept.
Cincinnati, OH
Title #3100258781
Title issued
09/04/1996 60,349 Kentucky
Motor Vehicle Dept.
Walton, KY
Title #962480590112
Title or registration issued
10/27/1998 78,000 Kentucky
Motor Vehicle Dept.
Covington, KY
Title #983000590080
04/16/1999 78,785 Kentucky
Motor Vehicle Dept.
Erlanger, KY
Title #991060590143
Report Summary
1. ACCIDENT CHECK
3. LEMON CHECK®
4. OWNERSHIP CHECK
5. RECALL CHECK
6. WARRANTY CHECK
Body Style: COUPE
Engine: 2.0L L4 FI
Fuel: GASOLINE
Total Loss Check:
Date: Mileage:
10/15/1993 52,984
09/04/1996 60,349
10/27/1998 78,000
04/16/1999 78,785
Lemon Check FAQs:
Ownership History:
Types of Owners:
Recall Check FAQs:
Date:
Mileage Reading:
Source:
General Comments:
09/10/1993 Ohio
Motor Vehicle Dept.
Xenia, OH
Title #2900042256
Title issued
Motor Vehicle Dept.
Cincinnati, OH
Title #3100258781
Title issued
Motor Vehicle Dept.
Walton, KY
Title #962480590112
Motor Vehicle Dept.
Covington, KY
Title #983000590080
Motor Vehicle Dept.
Erlanger, KY
Title #991060590143
