Advice: Wheel Bearing Replacement/Nicked Hub
His procedure was sound, race just started crooked which is strange since the shoulder that faces down is usually radiused.
I press mine but driving with a tool or ground down race as per @thomasmryan would be fine.
See PM @pointFive , if the 944T hub is same, I have an early good one you can have free.
Still, hub is usable.
I would at least rub an emery cloth light on the indentation.
When you look at damage like this in aluminum with a magnifying glass, there is raised material next to the indention just like if you ran a plow through dirt. It's this material that will make the bore dimension smaller than it was originally.
T
T
Well I was able to get to work today, but my mind is still racing wondering if I cleaned the wheel hub good enough (had a machine shop install the races. the machinist used an oil/lubricant to install them, additional material was removed (nicks/scores) by the machinist as well, hoping I didn't leave any
FOD behind), if I used enough grease, that the bearings are seated correctly, and all fasteners were torqued...
When testing for slop (wiggling at 12-6 and 3-9 on the tire), there is still movement. Not nearly as much, but it's still there. I jacked the car back up to re-check the clamping nut. I re-tightened the clamping nut then backed off until the aft washer could barely move. The hex bolt was then torqued to 10 ft-lb (lowest setting on my wrench) while the lug nuts were torqued to 96 ft-lb.
Being the first time replacing wheel bearings, it surely is nerve-racking...
Thanks @951and944S, @odonnell , and everyone else who helped out!
If the bearings are seated properly by rotating the disc and turning the clamping in until the washer can just be moved with a screwdriver, and there is still movement, then check suspension pickup points, the steering to rods, steering box, steering box attachments, and macpherson strut attachments. There should be no noticeable movement.
