Pass on a 944 S?
#31
I had those slotted manhole covers on my 86.5 928 too. I don't know why but I like them.
I'm loving this thread....lotsa great info on the 16V'ers.
#32
@Otto Mechanic What you can do with your Sewer Lids to make them run cooler is have them converted to CS wheels. If you look at the back of Sewer Lids the factory already marked out “cut outs” so a shop could easily machine the extra metal.
makros (06-20-2021)
#33
@Tom R. I think you are confusing the forged Club Sprort (CS) wheels with forged Sewer Lids. It was the CS wheels that were fitted to the 951S optioned cars and it’s the CS that look similar to the cast D90’s.
#34
Original FUCHS wheel which first came on the scene on early 911/912s
Manhole, sewer lids, trashcan lids, seven slots, the German name is 'Gullydeckel',
they are also made by FUCHS and are forged al. alloy like the first image
'89 turbo wearing the forged alloy Club Sports made by FUCHS
makros (06-20-2021)
#35
the last two images above are different offsets and widths but made by FUCHS in a heat treated, pressure forged manufacturing process for lightness and strength.
the D90 is a cast wheel with different lips and I believe are made by Ronal in Germany.
( the only set of wheels I don't own for these cars, so cannot verify on the maker )
the FUCHS on the Ruby red 'sunroof delete lightweight' in middle image are also 16s like the ones on the turbo in Sapphire, but differ in width and offset. It is true they do not allow as much air passing to cool brakes in long track sessions, but are extremely strong wheels. They carry the Porsche parts numbers, the Fox head mark of all FUCHS wheels, and show a definite line on the back of the slots where the cutouts would be on the ClubSports, just as mentioned above by MAGK44. Earlier dated wheels do not.
The other thing about the forged FUCHS vs. the D90s, is the finish. D90s are painted, the FUCHS whether original manholes, pie plates, lids, etc., all have an anodized finish in silver or platinum. Weissach 928s had a color unique to the anodizing and sometimes do show up on the market. In the used realm, keep a close eye on sizing, as there are many offsets and apps from 911 to 928 to 944S to 951.
And I believe the Club Sports wheels were only offered on 951s of '88.2 and '89 model year, and 928 GTS and S4 variants. None were offered on the 911, because offsets were changed from the G model 911 cars which DID utilize some offerings of the Gullydeckel as an option.
makros (06-20-2021)
#36
The forged Trash Lids also have the engraving but they look totally different to Club Sports however, like I said above, you can convert them quite easily to Club Sports.
#37
Yes the cast D90’s and forged Club Sports look the same at a glance, on closer inspection the engraving confirms the Club Sports.
Thanks for the description, I had no idea those wheels could be converted. I have a complete set of 4 on my parts car I could send out. I'm pretty sure mine are anodized instead of powder coated. I'd need to find someone to not only machine them to the CS shape but also do the outside engraving since it looks to me like cutting them to the CS spec will also cut out the manhole engraving. Then the wheels would need to be anodized again?
Any referrals?
Regards,
#38
Mike -
Any referrals?
Regards,
Any referrals?
Regards,
#39
I had the CS on my 89 951, D90s on my 3 S2s, and for some reason didn't see the obvious difference to the sewer lids. Round v square opening. Cant be more obvious than that. I've been in M Roadster useless info for too long.
I have a set of 7" D90s to get rid of now that the 944S is gone. They were painted, and like I said above they don't work on the track with stock NA brakes.
#40
Otto-
Since it appears you are on the West Coast,
you have seen or heard of Weidman Wheel Refinishing in northern CA have you not ?
He comes highly recommended in the wheel restoration and refinishing business, but has a long waiting list and is quite expensive.
Al Reed in Southern CA is another great refinisher out your way. He and Harvey Weidman have both done wheels for me and I would highly recommend either
makros (06-20-2021)
#41
Forgive me, I'm dyslexic; I forgot the eyebrow engraving is on the outside of the cutout, not the inside.
Thanks for the tip. I expect I'll do this.
#42
Otto-
Regards,
Scott.
#43
What turbo parts are on a S? Not the brakes, not the sway bars, not the head, not even the wheels. Definitely not the steering wheel unless it is a S with the airbag option. They do have the same doors and hood.
What standard turbo parts are on the S2? 1988 sway bars, brakes, bumper, header, steering wheel, rear diffuser. Don't forget the spare tire. What standard S2 part is not on the turbo (at least not on the 88 turbo unless added as an option)? ABS
The engine is obviously using parts from a 928 (the cam hold down brackets, the top end tensioners etc. BUT the gaskets are 951. I don't recall the rod bearings, i think those were 951 as well.
On the suspension, the control arms, bushings (sway bar and otherwise), caster blocks all 951. Sway bar was actually larger than the turbo from 86, i don't know part number, but i had a back and forth with the parts folks because i thought it was standard 944, and turned out to be larger. Clutch was also for a 951/s2, i took out the rubber centered one, granted it was already replaced once (i think the previous owner had it done, wish i knew.)
basically i came to the conclusion that the S is a great value. It is more robust than an 8v 944 given the 951 parts used, but cheaper than a 951/s2 because of the body style?
On the rear, same thing. Yes the brakes are from a 944, but the trans has hardened parts akin to a 951, with different gear ratios.
#44
FYI, there is a 944S currently up for bid on Bring a Trailer (no affiliation)
https://bringatrailer.com/listing/1987-porsche-944s-14/
Looks to be a nice lower mileage car.
#45
