Is This A Decal
Is the rough paint, stone gaurd stuff below the door sills a decal or a special type of paint/application. See pic below.
Mine is deteriorated in sections and I was wondeering how to renew it.
Rennlist Hoonigan
which cost no drachmas
You can commonly find it at paint supply stores as stoneguard. They do have it in some colors, but on the 944 it's applied underneath the paint. Germans usually call it body shutz.
Matt
Matt
I resprayed my old 924 with the stone guard stuff.....bought it at an auto parts place a long time ago.....its expensive....around $10 a can....my car was dolomite grey and I sprayed this area black.....looked good when finished.....
what about usint the new stuff that is smooth, clear and that you can buy in sheets and apply over the paint? Would that stuff work as well in that area? I think it would look better.
Mark
Mark
You spray it on and let it dry for 4-5 hours than sand with 80 grit. Use a paint degreaser to clean the panel and paint. I've got in on the GT fiberglass frontend, along the lower rocker panels and up the front portion of the rear flares, also from GT Racing. BTW, I've built a 924GTS replica and I'll be showing it off at the 24 Hours this weekend at Daytona.
Steve
Steve
yeah its undercoating (to answer the question)
steve - my roomates and i will also be at the rolex. i have an '84 944, and my roommates are sporting '87 951 and '79 911 SC. we also have another 951'er coming from tampa. i'm sure there will be other rennlisters there. we need to start a thread for this. i'm looking forward to seeing you there, i'll have my camera handy for sure!
-Michael-
-Michael-
Hey;
It is a product marketed by Wurth, manufactured by AutoFit (IIRC). It is a rubberized rocker shutz. It is different from the underbody shutz, as it is thinner and sprays on smoother. There are other "similar" products out there, but they may not match the OE appearence or durability. It is NOT easy to get the OE texture. It takes some practice. Some of the more modern versions can be tinted to more closely approximate body color which helps hide scrapes and chips. It comes in black or tan.
Clear 3M film is NOT easy to install, will not go around corners, and is expensive. NOT a good solution for this application.
Have you got any pics for those of us that are stuck in the snowy part of the country?
