anybody use loctite on CV bolts?
Old 01-20-2004, 12:02 PM
joseph mitro
joseph mitro's Avatar
Default anybody use loctite on CV bolts?
I've seen several tech articles including clarks garage, but have not seen any reference to this, although I thought I've heard of people doing this. Several of my current CV joint bolts are loose right now.
And what type of loctite?
thanks
Old 01-20-2004, 12:10 PM
Luis de Prat
Luis de Prat's Avatar
Check out this thread in the 951 Forum. Danno recommends Loctite Blue in the final post:
https://rennlist.com/forums/showthre...hreadid=109227
Old 01-20-2004, 12:14 PM
Dal Heger
Dal Heger's Avatar
If you are using NEW bolts then it's not required, but if you are re-using the bolts then it's a good idea. I use loctite blue on those.
Dal.
Old 01-20-2004, 12:18 PM
joseph mitro
thanks, excellent tips there
Old 01-20-2004, 12:20 PM
M758
M758's Avatar
It is good idea to use blue on new bolts and not to used old bolts at all.
Make sure you thoughly clean the threads and the holes to ensure there is no grease there.
Tighten to 30 ftlbs.
I had a set of bolts back out after installed new bolts and used loctite, but did not full clean the threads. Believe me it sucks to have the bolts back out on you on the road.
Old 01-20-2004, 12:27 PM
joseph mitro
coming from experience, i presume?
Old 01-20-2004, 12:30 PM
M758
M758's Avatar
Yep,
I was stuck on the AZ freeway in the middle of summer in the afternoon rush hour.
Luckily I was able to get home with a friend and go back to the car an install some old bolts for the ride home.
While the half shaft was faling about it took out the speedo sender on the tranny and ended up jambed between the exaust pipe and the tranny.
Not a fun experinece.
Old 01-20-2004, 04:49 PM
Skip
Skip's Avatar
Loctite Blue is threadlocker #242 - depending on how.where you buy it, it's not always in a blue tube. The threadlocker not only helps ensure a good lasting fit, but also prevents rust and corrosion so the next time you're in there it's not so painful to remove.
Also, Loctite has just released new versions of their popular threadlockers and anti-sieze that are "sticks". I find them a little easier to use on bolts, etc. The new medium threadlocker stick equivalent to #242 is #248. for high strength semi-permanent bonding, use Loctite Red threadlocker #262 or stick #268.
FWIW, I use the threadlocker #242/248 on the Koni insert rebuilds and conversions as well... just as an extra measure of safety as they are already lock-washered.
Old 01-20-2004, 10:43 PM
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
Matt Romanowski's Avatar
Another thing to remember is that everything is clean when you use loctite. If there is any grease / oil, it won't work.
Matt
Old 01-20-2004, 11:18 PM
sayporsha
sayporsha's Avatar
I always clean the threads with brake cleaner & cotton swabs until they're BONE DRY. Stuff a paper towel behind the flange when spraying so it doesn't shoot into the trans or wheel bearing seals. I've done this on 4 different axles, and they're always tight when I check them before a DE event. I don't use Loctite, but it's not a bad idea. It just makes it harder to clean up the threads next time.
Old 01-21-2004, 07:22 PM
joseph mitro
another reason not to use old bolts....
i just finished my passenger side CV joints today - cleaned and repacked. for some stupid reason i bought enough new bolts to use 5 on each joint, and use 1 old bolt per joint. on the final round of tightening everything, the old bolt on the outboard joint snapped. i had to completely remove the axle to remove the remaining fragment. added another hour to my job. from now on - use ONLY brand new CV bolts
Old 01-21-2004, 07:36 PM
Manning
Manning's Avatar
I think I recall reading in either an old thread or Pano that the bolts are torque to yeild, so you actually really, really should not reuse them as Joseph found out.
The pinhead who worked on my old Scirocco didn't tighten the bolts properly when he replaced my CVs and the bolts backed out on the driver side inner CV. It all came loose at a traffic light. Got on the gas and the revs went through the roof but no motion. Pouring rain and near freezing. Not fun.
Old 01-21-2004, 08:42 PM
Bill
Bill's Avatar
I personally would not use Loctite blue on the CV bolts.
Anyone that has removed those "Damn#ioi$ky" cheese head bolts know how easy it is to strip the bolts.
Remembering this, now think how it would be to remove the cheesy bolts WITH locktite on them!
Just use new factory bolts and the next time you remove them, you will thank me.
For anyone that is removing and reinstalling the CV's with any frequency (couldn't imagine why) I would recommend installing safety wires.
Again....no locktite.
Old 01-21-2004, 09:08 PM
iloveporsches
iloveporsches's Avatar
Last winter I did a clutch job. I did just about everything you're NOT supposed to do when I put the CV joints back on. I reused the bolts, didn't use locktite, didn't even clean the threads all that particularly well. I've put anywhere between 2500 and 5000 miles on them, and just checked them a week or two ago. All of them are still tight as spec calls for. Of course, at the time I didn't know, and I really wouldn't recommend doing it, I just got lucky.
Anyone know if the 12 pointed bolts offer any engineering benefit, or were they just invented solely to **** mechanics off?
Old 01-21-2004, 09:14 PM
Tom M'Guinn
Tom M'Guinn's Avatar
I have heard of people using safety wire. Never tried it though.
Quick Reply: anybody use loctite on CV bolts?
