Project Nine - Program 944
#121
In these two images I'm making a template for the fiberglass mat. Having the mat pre-cut really speeds up the process during lay-up.
The first fender fresh out of the mould.
#122
The passenger side fenders are complete! Now for trimming and a test fit before continuing with the drivers side.
Here's a link to the Project Nine episode that includes a time laps of the fender lay-up.
Project Nine Ep.5 - Fender flare production
#123
Hi
No I'm running an LS 3 with 480hp was thinking of going to an LS 7 or built LS3 with 600 hp
I'm just not sure that the transmission can handle that much power the blowing up it seems to handle the 480 OK.
Not sure what would happen with the Additional horsepower any ideas?
#124
Test fit....
The fenders are trimmed, I've spent about 15 min. with a rasp fitting the fenders, and then taped them to this chassis. Both of the wheels pictured are from the front of my racer. Size 18x12 with a 335/30 fitted. On the rear a 2" spacer was added to bring the wheel flush with the fender. At a later date I'll publish optimum wheel specifications.
#125
Hi
As long as you keep it cool (the trans) and drive sensibly, you should be good.
#127
...and now a group of images with the vents trimmed out of the fenders as intended. The fenders are only fitted to the chassis with tape as you will notice. The car is not yet ready for fenders.
#131
This ole' girl is going to get the royal treatment, I'm just getting warmed up. Hahaha
Look for a build thread exclusively on this chassis very soon.
#132
The Project Nine 944 Over Fender Widebody Flares are now available for purchase.
A great introductory price is being offered until the first of the new year...
PROJECT NINE 944 Over Fender Widebody Flares
#133
#135
Probably won't be flush over the 968's moulded sills and sill gaskets, although the broadfoot flares can work with 968's so maybe someone who has fitted those to a 968 can chime in.
