Combustion chamber volume
Hey guys,
Does anybody know the combustion chamber volume in cc of a 2.5 l N/A head that is shaved down .030 ?
It should be in the fifties but need to know the exact numbers as i don’t have access to my engine at this time !
Thank you
Thank you
Sorry, Arominus, but I don't see how you come up with 55 cc's. Here are the relevant engine specs for our calculations - let's start and calculate engine displacement, which is 2,479 cc's for the 8V 2.5 liter engine:
Piston area x stroke x number of cylinders = 3.14159 x 5^2 x 7.89 x 4 = 2,479 cc
Bingo, formula is correct...
Now, let's calculate engine displacement based on "shaving off" 0.030". To complete this calculation we must convert to metric - 0.030" equals 0.75mm, which we must deduct from 78.90 mm (stroke). That's 78.15mm
Piston area x stroke x number of cylinders = 3.14159 x 5^2 x 7.815 x 4 = 2,455 cc
Now we deduct 2,455 cc's from 2479 cc's and the result is 24 cc's. Sorry for the inaccuracies in my earlier calculation but I only used 3.14 for the constant number pi...
So, how did you come up with 55 cc's...
- Bore - 100mm
- Stroke - 78.9 mm
Rainman
55-60cc is the measured combustion chamber volume of an 8v 944 head.
the OP asked what the CC change in combustion chamber volume would be by cutting the cylinder head.
nothing to do with the engine stroke like your math is suggesting.
the OP could shave 0.030" off his head and still have a 2479cc engine.
Shaving the head means removing material from the head seat to increase CR, correct? By doing so the engine displacement will be reduced to allow for higher compression or did I miss something...
Considering the variation that Spencer quoted, i would say the only accurate way to know the actual volume would be to CC the chambers after the cut.
The combustion chamber is not the same size as the cylinder.
Your formula assumes it is.
T
T
