Freewheel alternator pulley (OAP or OAD) upgrade
I'd like to upgrade my 944/968 altenator pulley to a freewheel alternator pulley (OAP or OAD).
http://www.eurekamagazine.co.uk/desi...-engine/39568/
Does anyone know, which one is PnP on a 944/968 alternator?
TIA
TIA
But at first I have to find a suitable.
Rainman
Think I've heard of people putting a simple switch on the field wire to deactivate the alternator and make it like a freewheeling pulley.
no real hardware changes required.
that said a 944 alternator at 100% output might consume 1.5hp (115 amp @ 14 volts, 80% efficiency)
Contrary to a rigid wheel the overrunning alternator pulley opens in overhauling direction. In addition, the overrunning alternator pulley decouples the alternator's inertial torque during a significant engine speed deceleration such as changing gears. The engine doesn't have to accelerate/deccelarate the alternator after the gear change. I like this idea.
Imagine a drag race, just rev up and let the clutch go, no need to accelerate the alternator again, when you shift up.
The crankshaft does never rotate at the same speed (rotational irregularities). So the OAP allows the alternator to freewheel when the belt speed (crankshaft speed) drops. It only transfers the accelerating proportion of the crankshaft forces to the alternator.
H.F.B.
Thanks for introducing this topic. I love the idea of upgrading my car to newer technology, and it seems that there are some nice benefits to using a more advanced pulley like this. You mentioned a part number in a later post, 234569, I can see in PET catalogs for 944 that there are two Porsche part numbers listed overt the years for 944 pulleys:
Early
944 603 121 06
Late
944 603 021 01
Do you happen to know whether the 234569 part number matches one or both of these Porsche part numbers? I am actually interested in a replacement for the pulley on my 968, which is yet a third part number ( 928 603 021 01) so I am most interested in finding out if there is a freewheeling pulley that will be a match for this part number.
Thanks and Best Regards
Nathan
Early
944 603 121 06
Late
944 603 021 01
Nathan
Rainman
could you direct me to the catalog where you found that pulley pictured above, i would like to see if there is possibly a v-belt option of this technology available (doubtful, but worth a look).
Here you go --> heavy 127MB PDF-file or go to https://hc-cargo.co.uk/downloads then navigate to HC-Cargo Catalogues and HC-Cargo Starter & Alternators or HC-Cargo Alternator Components.
There is much more interesting stuff to find.
Very interesting indeed.
So do we know which 944 model years this pulley will fit? I'd be interested in one for an early car.
Approximate price?
Edit: Found the price to be around 50 euros!
Approximate price?
The 234569 is the same as the very common LUK or INA 535006010 pulley
Above is what I got today and it fits on my 968 alternator nicely.
It won't fit on an early alternator. The early pulley got 5 grooves and Dim./1.goove is 7.00mm. So I think for an early alternator the pulley with the Cargo #230304 could fit. But I don't really know. -->Here is a reference list
Would adding this affect the mechanical balance of an alternator and cause vibration?
I don’t know if they even balance the rotor/shaft/pulley on an alternator, I would imagine they bench balance as a rotating assembly. Just a thought for discussion, carry on.
