2.5 to a 2.8
The longer stroke helps low end TQ more- although,when done correctly, the 2.8L bore is supposed to help TQ a lot too- generally speaking, the longer stroke helps TQ & larger bore helps high winding HP.... again, GENERALLY....
Yea I have hear of that too about the bigger stroke is GENERALLY TQ and bigger bore is GENERALLY better for higher HP in the upper range. Most of the big V-8's have a bigger stroke then bore which helps them to get that low end TQ but they suffer it with less HP in the upper range. Do a search on this because there was just a thread that was VERY imforative about this issue. They went off on how different car companies do certain things to the motor of get the low end TQ.
No, a stroker kit indeed, increases stroke. I *believe* you would hit 3.2L by doing both a bore and stroke. If I were you I would call SFR, Anderson, or Huntley. I have no aff with any of them, but they all do a version of what you are looking for.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Originally posted by Boricua944
So the 2.8 stroker kit gives a bigger bore and longer stoke? So you would need to dissasemble your engine and take the block to get bored over correct?
The factory '89 2.7 liter motor uses the old 2.5 liter crank with bigger 3.0 liter bores.
The factory 3 liter motors use the bigger bores and bigger crank.
BTW, I don't know of anyplace to get a "kit," usually one would just but the all the peices (crank, rods, custom pistons, rings, bearings, etc).
Unlike a chevy small block, you can't just bore the cylinders to a new size. There is 1 overbore AFAIK and pistons are hard to find (and $$$). Boring the Alusil block is only the first step, the second step is etching the cylinders so that a small amount of aluminum is removed but the silicon crystals are left behind, finally the cylinder is honed to bring the silicon to the proper dimension, leaving a cylinder wall that is mostly silicon. A lot of machine shops won't touch it.
This will only give you a few CCs (0.5mm larger postons), to do a 2.7 or 2.8 is a different process. The cylinder walls are not thick enough to bore for a 104 or 106mm piston so sleeves must be installed, IIRC the entire cylinder is basically machined out and replaced. Add the cost of the machine work to the custom pistons and 3l crank and you can expect to drop some serious cash.
