Quick! Dme Relay Replacement Questions!
Wax On, Wax Off
Alright. I'm in the middle of the process of switchin out the DME relay. Here's what I need to know.
-Should I un-plug the negative terminal of the battery?
-I've got the second fuse box moved, and it's still a bitch to get out. do I keep wiggling it until it comes out or is there another trick?
-Porschephile
-Porschephile
I assume this is the 924s.
A pair of latex gloves, and some gentle rocking of the DME relay will help.
I personally would not use a screwdriver, particularly when the battery negative cable is left in.
Wax On, Wax Off
How many prongs on the 924S/944 DME relay? the one I got from Pelican has 4, the one I got from the 924S has 6....I'm lost, confused, and starting to get angered
Wax On, Wax Off
someone wanna do a PET check? or answer this cuz they know it off the top of thier heads? the new DME relay I got has the part number:
993-615-227-00
is that right or do I need a different one? it's a 1987 924S.
993-615-227-00
Wax On, Wax Off
Positive. reading it off the box that Pelican sent me. so I should have
944.615.227.00? here is what the box on the 4 prong one says:
Fuel Pump/DME relay, 944 (#2 position 83-85/1), 944 (1985/2-91), 924S, 968, 911 carrera 2/4 (198
<bar code>
993-615-227-00
<bar code>
993-615-227-00
