Any tricks to getting the crank pulley off?
I'm doing a lot of work to my 87S including all new front seals. The crank seal needs replacing plus I have a new geared sleeve to install. However, the bloody thing is stuck hard. I can only get about 1mm of movement.
So far I've tried pullers that are causing a little damage so I don't want to get to aggressive. It's pretty frustrating. Any tricks from those that have run into this before?
Chris
Chris
Rainman
where do you get a 5.5" channel lock? LOL
rubber mallet against the face of the pulley (perpendicular to the ground), tapped around in a circle, and a few taps on the belt groove side (to give it some radial jiggling) between gear puller sessions usually gets it.
penetrating oil helps unstick from the woodruff key too.
Whoops, I was thinking about the oil pump drive sleeve. Pulley itself comes off with 4-off M6 bolts. The drive gears for the belts just slip off but the woodruff key can cause them to stick. I would tap them inward lightly to break them free. And tap on the edges in a circular motion lightly until you can work it off.
Of course. A puller isn't really getting behind it but that's my only option. It probably hasn't been off in 30 years so it's a bit stuck to the crank. The balance shaft gear I've had off before so that was no problem.
Rainman
i misunderstood originally - i thought you were fighting the accessory (AC/alt) pulley, not the timing belt drive gear.
yea, that one gets sticky sometimes.
can you (carefully) apply heat with a mini torch of some kind ?
Oh I misunderstood too. If memory serves, I had to grind and modify a puller to get a good grip on that one.
Chris
Chris
Now I'm not sure if it's not a left-hand thread.
Could you do my a favour and confirm, that's a normal right-hand thread on the bolt. Thank you.
Good luck removing your stuck crank pulley. I hope mine will go off easier.
Tomorrow I will buy another/better socket.
failed 24mm socket
$2 Taiwan socket.
Thanks, got it out. The "No Taiwan socket" did it.
crank pulley
$2 Taiwan socket.
crank pulley
