88 vs. 87 na intake?
Intake P/N is 944.110.052.02 it is an updated (for MY1988) p/n but it appears the same according to PET it looks like it replaced 944.110.051.09 (PET refers to that number as the dropped p/n #, use the one I gave first as replacement).
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
I could have sworn it was a change in CR but I could be wrong, wont be the last time either. :>)
Matt... Now that I think about it you are correct. For some reason I was thinking the intake and/or exhaust was changed. So to get the same HP in an 87 you need to swap head for an 88? D
Again, just conjecture but I thought the difference is in the pistons not the head. The head has the same note about the p/n update. It has been a while since I had an NA though.
That must be the case here are the numbers from the manual
to 87 - Bore 3.94; stroke 3.11; CR 9.5:1; HP 150
88 (8 valve) - Bore 3.94; Stroke 3.11; CR 10.2:1; HP 160 (158 SAE corrected)
It appears the the "dish" of the piston was reduce in MY1988 in order to raise the CR. The ROW piston is a flat top piston (acording to the pictures in manuals) so that is where I make the assumption of difference. For the 2.7L it was reduced to about a dime from say a 1" diameter depression.
Matt is right. The 88 pistons are different and higher compression. I had an 88 motor taken apart and the pistons has a smaller indentation than the earlier years.
