I gave my 944T head to the shop for a rebuild.
I also brought seals and valve guides (Got the 944.104.328.51 - 1st oversize).
Today a received a call from the shop that the guides brought are too big to fit and he told me I need to bring him the standard size.
In the PET and on all major store websites I see only the 1st oversize and I understand that they need to be grind to the correct size 0.06-0.08 press fit according to the workshop manual.
Is the machine shop owner correct that the standard size is available and should be used instead of the guides I bought?
I am based in Israel so each change like that has a lengthy turnaround time as I need to order the parts from abroad...
You can still get "original size" from Porsche, directly.
I see, thank you.
The engine has over 100K miles.
Is there a downside to using the original size (I am asking because they seem quite hard to trace in shops)?
Don't know, I've only ever bought/used the 1st oversize and never had a problem (never had a shop tell me they couldn't make it work, have had lots of 944 heads done over the years)
Head was back from the shop last week and today I finally finished putting everything back together and got the engine back alive.
First couple of minutes were scary as the engine sounded like it was about to blow up (I read about the lifters knocking, but when I heard the noise live, I was really scared).
I stopped the engine within a couple of seconds and took apart the oil filter to make sure oil was going through it.
It was full of oil which brought my hopes up again.
I started the engine again and it sounded much better.
After the engine started to heat up, smoke and strong exhaust smell came from the exhaust manifold side.
This is where I am at the moment. Waiting for the engine to cool down so that I can check what's wrong with it.
I did put the exhaust header gaskets and torqued it to spec.
on the two connections to the exhaust pipes, I put new metal rings for sealing.
I could not torque it exactly to spec as access is very limited to these nuts and bolts, but I did make sure it was quite tight.
Is there and other sealing rings or gasket that need to go in there?
