How could air get into clutch hydraulics...?
Rainman
have a local "foreign car parts" shop i'll visit today, they said they have the blue clutch hose on hand, will give them a shot with the MC/SC/etc for pricing vs Pelican.
Before you go out shopping for parts [BMC, CMC, CSC], put a fresh liter of fluid through the [brake and] clutch lines.
Rainman
more like 50k miles if that.
and not from the slave, that i can recall. only at brakes (removed rear suspension a few times).
i already have the new clutch cylinders on hand. place down the street was within $5 total of Pelican and got me stuff next day.
will just flush thru the brake system.
but yeah, never knew there was a service interval for brake fluid.
Amazing! How about the coolant? there is a service interval on that also. some guys say 2 years, other guys say 5...I'm with the 5 year interval crowd..at least on my Camry...or when I get around to it.
Report back on if that FTE pressure hose fits, someone said early cars needed one slightly longer or something. I have one on hand and have that job coming up.
Rainman
anyone confirm that the 944 clutch system is supposed to be inverted flare, not bubble flare?
thought euro cars tended to be bubble flare.
the MC/SC/line i got are inverted flare so they should all work together fine, just curious.
The tests for moisture will always show zero because water/silicone it is like oil and vinegar, if you test the oil, it will never have vinegar.
Wait. I'm thinking brake lines.
My 928 is an auto. All of the brake lines on it are bubble. When I took apart the brakes on the 944S2 I recall they were also bubble. I can't be sure about the clutch lines on either.
