87 944S - Anyone replace the fuel damper hoses? What size?
So I noticed that the bottom of the hose that runs from the rail to the damper is worn in one spot because it was rubbing against a hose clamp. Grrr.
I'd really want to replace these hoses all together as they are old anyways. Clearly Porsche wants you to buy a replacement rail with hoses attached. There has to be a way to replace these.
Any tips?
Chris
Any tips?
Chris
Rainman
There are two types of rail - one has press-fit "pushlok" type hoses and the other has threaded fittings...if yours is threaded just have a local hydraulic repair shop rebuild the hose for you.
If you have the pushlock I've seen them just cut off the original hose and secure a new piece of suitable diameter secured with a hose clamp (screw or oetiker type)
