door sill interior trim removal?
I'm want to route some stereo wires under the carpet.
Looking to remove this black plastic trim on the lower edge of the door opening. Is there any best way to remove this (before i just start pulling on it)? Thank you.
You gotta pull up hard but don't try to pull up each clip all the way before moving on. Start at one end and get it moving, move down a ways and get that up a bit and when you get to the end, start back at the beginning pulling it up just a bit more. If you try to get one end all the way up before moving onto the next clip, it will break. Same for putting it back on. It's the only way to get them on and off in one piece. And whatever you do, don't try doing it when it's cold. The warmer, the better.
