Broken Crank
Rennlist Hoonigan
which cost no drachmas
Broken Crank
Broke the crank in my 2270. Broke in the webbing between the rod journals for cylinders 1 and 3. I'll have to figure out what to do know.
Big thirst, Sore Thumbs
Napoleon
Napoleon
Cool. Make sure you use something to hold it in place while it's curing.
I recommend a shoelace.
Or maybe a couple of them. I mean that is a high precision part. Yeah and get those nice wide shoelaces.
As I mentioned on 914world Matt, I have a 2270 crank on the shelf. It has some cosmetic damage to the journals from an exploded pistons but it looks like you do a lot of modification to the journals anyway... It is at McMark's shop in Sonoma CA and if you want it get a hold of either him or me...
Official Wednesday AM Red Bull F1 test driver
What did that sound like when it went??? What other damage before you could turn it off?? Could have looked something like Vettels Renault when it let go, of course it was probably going over about 4X the revs when it did...
Rennlist Hoonigan
There was nothing wrong except for the seized bearing and the broken crank. The heads, pistons, cylinders, rods are all fine. It messed up the dowel pin for the bearing a little bit, but with some ingenuity I think I can save the case.
think magnafluxing it will find the crack???
amazing the rest of held together- good thing you got the clutch in fast!! Or maybe it would have skidded to a stop!!
Rennlist Hoonigan
The motor is well built and runs a web 86b/c cam. Never dynoed it, but it was putting out around 175 horse.
Wow, I was way off! Matt's car is a stupid fast, he and I both saw 150 at the back straight at the Glen and that was stock brake calipers!!!!!
Rennlist Hoonigan
Posting over on the 914world boards, it seems like broken cranks are becoming more common. I wish it would have happened to someone else though....
I have a factory 1.8 crank if you need it...
