What's your 914 "project" this week?
#47
This coming weekend should be the end of the line for a recently started project. It started out just replacing the suspension bushings but then I got a bad case of "as long as I have the damn thing apart..." So, I ended up installing Elephant Bushings front and rear, new rear bearings, five lug conversion, Tarret bar in front, brake caliper rebuild with new rotors, and I think that is it... What should have taken a weekend took 6 weekends due to buying bad rebuilt calipers and having to rebuild them again. I also had to wait on parts from Germany. I should drop it off for alignment and corner balance Monday... It sure is pretty! Hope it all works!
#48
#51
When I got done installing the rear control arms, before hooking up the shocks I pushed up on the control arms and it was so easy and smooth. Now I have full travel without stiction... I cannot wait to drive it.
#53
Actually, I did unload it to a local guy here... Sorry. I do have an extra rear sway bar... You should really get some though... Friends don't let friends drive 914s without swaybars... and this is why!
#54
Haha that looks like great fun actually. Not in the sense of functionality though.
I had some "aftermarket" sway bars on the ca. They were bolted with four bolts to the front and rear trunk respectively, with some electrical tape wrapped around it, attached at the top to the trunk floor with some thin metal U-bracket (homedepot plumbing department) and attached to the A-Arms via another weird bracket and some standard ford drop links (four rubbers, long bolt). They did not work I think.
I'll find some sooner or later
#55
Last weekend, Matt Romanowski and I put out two 914's away for the winter. My parents have 4 spots to park cars at their place during the winter when they go to Florida. When they leave we fill up their garage! It is a sweet deal, but sad at the same time. The cars are always running so well when we put them away.
#56
Well, finally got some time and garage space so I tackled the engine drop and some body disassembly Sat. night. I also wanted to try out my new Nikon digital after being without a camera for about 2 months. For my first time under one of these cars, the drop wasn't too bad. Now see if you can spot the 3 2.0 engines in the pic!
#57
![nono](https://rennlist.com/forums/graemlins/nono.gif)
#58
Basic Sponsor
Can we amend this thread to just say "What's your 914 "Project" Period? I mean...does anything ever only take a week? And...are we EVER done???
I would list all my projects, but they are way too numerous, and way to complicated to fill just one posting. But here's a few.......
Papa Smurf Winter Projects:
-Limited Slip
-REDUCE WEIGHT in any area I can still find
-fix 1st gear
-rewire the entire car to get rid of all those extra and heavy wires
-re-duct the oil cooler so it doesn't dump hot air UNDER the car and create lift instead of downforce
-new rearview mirror so I can actually see who's next to me in a turn now that I have to wear a Hans device
-fix some of the broken fiberglass on the front splitter from my landscaping job at VIR
-valve adjustment
-new brakes and rotors, brake flush, etc.
-I'm sure I'm missing something....
Huey:
-get the 2.7 engine running...
-...only to take it out, replace all the sheet metal, wires, etc
-rewire the engine compartment for easy quick disconnect wires
-replace steering rack
-replace bushings in front suspension
-fix oil leaks in 2.7 engine
-fix a few nagging guage issues
-re-weld rear deck hinge mount
-carpet??
-more that I can't think of off the top of my head....
Black 914 race car:
-Get race engine back in car
-SELL CAR
I HOPE that's all....
-Limited Slip
-fix 1st gear
-valve adjustment
Huey:
-carpet??
Black 914 race car:
-SELL CAR
Bob Saville
![](https://naroescapemotorsports.com/wp-content/uploads/2018/01/naroescape-logo-small.gif)
Getting You On Track!
www.naroescapemotorsports.com
704-395-2975
'07 SPC
'71 914/6 Huey
'04 GT3
Bob Saville
704-395-2975
- Data Analysis & Coaching
- Drivers Gear
- Crew Gear
- Car Gear
'07 SPC
'71 914/6 Huey
'04 GT3
#59
hard to believe no one's touched their cars since last November! ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
ok.. ok.. I spent memorial day weekend replacing dried out rubber fuel lines in the engine compartment. Also did the vacumn lines.. just cause I could
#60
After getting the ol' 1.7 out about a month ago, I finally started it again and got it inspected yesterday. Being so busy with work and coaching I have been ignoring the 914 a lot this spring. It was good to drive it yesterday and I drove the long way home yesterday with the top off from the shop. Good to be back on the road!!!!!! Now summer can offically begin!
