What's your 914 "project" this week?
#31
What are 993 motors going for? A new 996 motor from Porsche is about $10-$12k.
Personally, I think the air cooled is the way to go. You'll likely have to widen the engine bay to fit either.
#33
Just a 914. I would restore a 914/6 back to factory original only, with maybe some internal engine upgrades. But I dont belive in ruining neat collector cars. They are what they are, and were in most case, something special in their day. That is why they are collector cars today.
#34
I can get 996 motors for about $7500 and 993 motors for about $10000. The ONLY reasons that I am even thinking of doing the 996 motor is that you get more HP for the money, and a Boxster S transmission would bolt up to it and be a much better transmission then the 915 or 901 trans.
I agree with you, but then I would be dealing with the 915 or 901 transmission. I would love to drive a car that has one of these transmissions set up. If I knew that one of these transmissions could shift smooth and fast and be up to the torque levels a 993 motor has then 993 motor all the way. Which is probably the way I will go, but it would sure be fun to jump on the trans. like you can in the boxster S.
#35
What happens when you jump on a Boxster S that a 901 or a 915 couldn't handle. If you are talking about doing a burn out then I don't know many clutches that will take it.
#36
I guess my main question is how smooth and crisp can a 901 or 915 shift in these cars. What I really need to do is take a trip down to Patrick motorsports to drive one that is in the 914 and that is rebuilt. Most 914's shift like crap compared to the boxster. (cable systems)
#38
While I think that my 914 shifts reasonably well, it leaves much to be desired. And for some reason after I put the shifter back into the car (with all new bushings at that) the shifting seems MORE sloppy. I'm thinking I might need to rebuild the old transmission. The first time I went to change the fluid, NOTHING came out. Still worked pretty sweet though!
#39
I think it must be possible to install one of the boxster cable type shifter systems in a 914.
My 914 has a traditional sloppy gearchange which works well unless you worry and think about it.
I must admit that the original design was rubbish and in my almost restored car I've swapped the original linkage for the side shifter linkage.
#40
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
When I finish this weekend, the car will go to a shop in Sac for a corner balanced alignment. It will have camber plates and monoballs, Tarret Bar, PROPERLY INSTALLED rack spacers aka bump steer kit, 180# springs, and Elephant Bushings. Also, for good measure the stock suspension components involved have been powdercoated. Should be sweet! Oh, and she will be wearing 16X6 5 lug Fuchs!
#41
I just need to drive my 914. I don't think I have driven it in 3 weeks. It has been raining everyday so I am worried about taking it out and I don't want to commute 45 miles with it in rush hour either.
#44
Nah no playtime for a while. I'm getting all the seals together. Not to mention trying to figure out how to put the seals in the doors and the glass and all that junk back together.
#45
Good morning guys, I'll add my project up here to keep things new. I've got a '73 Marathon blue car I'm going to start stripping this weekend to get ready for some new rockers and paint. Planning on a casual winter project to get her looking new again, and also starting to strip the extra 2.0 engine on a stand to begin the rebuild process. I'll have to put some pics up later as my damn digital was stolen at a party about two weeks ago
