914/914-6 Forum 1969-1976
Porsche 914 conversion
Old 09-23-2002 | 01:54 PM
SteveSr.'s Avatar
SteveSr.
Question Porsche 914 conversion
Hey fellow 914 fans,anyone have a non Porsche engine in their 914? I am in the process of installing a 3.1lte. v6 in mine,need advice about wiring the engine into the 914 system....ie..fuel injection......Steve
Old 09-23-2002 | 02:26 PM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
Post
I've not completed nor seen this conversion. I suggest you search for 914 and V-6's. I found one article regarding a V-8.
<a href="http://home3.inet.tele.dk/box164/index.html" target="_blank">http://home3.inet.tele.dk/box164/index.html</a>
Old 09-23-2002 | 04:39 PM
SteveSr.'s Avatar
SteveSr.
Talking
Thanks Rob for your reply,I think i've seen just about every site there is to see on 914 conversions and not found anybody running factory fuel injection. Maybe i'll have to figure it out my self,thats what hotrodding is all about right?....Thanks again....Steve
Old 09-23-2002 | 06:06 PM
bowlsb's Avatar
bowlsb
Post
Which fuel injection do you want to runn on that V6? What kind of V6 is it?
Old 09-24-2002 | 09:22 AM
SteveSr.'s Avatar
SteveSr.
Talking
Hi Jeff,It is a 1991 chevy corsica 3.1 with the factory port injection.I have the whole car so I've got the entire wire harness and computer.
Thanks for you reply....Steve
Old 09-24-2002 | 07:10 PM
bowlsb's Avatar
bowlsb
Post
Well golly Steve, I don't see how the stock 914 FI could in any way be adapted to work. I would basically adapt the original Corsica FI to the 914 or use aftermarket programmable FI, which basically means finding the 12V source off of the relay plate, and rewiring the fuel pump.
Old 09-24-2002 | 07:11 PM
bowlsb's Avatar
bowlsb
Post
You might also try the FI section on the STF site.
<a href="http://www.shoptalkforums.com/" target="_blank">http://www.shoptalkforums.com/</a>
Old 09-25-2002 | 09:17 AM
SteveSr.'s Avatar
SteveSr.
Post
Maybe you miss understood Jeff,what I meant was using the factory injection system that is on the Corsica,would it be as simple as finding the 12 volts on the relay plate and rewirering the fuel pump?....Steve..1971 Porsche 914/1.7
Old 09-25-2002 | 05:39 PM
bowlsb's Avatar
bowlsb
Post
Thats right...you will need the right pump for that engine. The 12V for the stock 914 FI is at the relay pate at wires 16/24 on the 4 pole plug at the end of the FI wiring harness. Check each white wire, they are numbered.
Old 09-27-2002 | 04:36 PM
SteveSr.'s Avatar
SteveSr.
Talking
That gives me an Idea Jeff,I'll find those hot wires at the end of the harness and hook them to the fuse block on the chevy harness with the whole blame thing wired back onto the engine while it is hanging on the engine stand and hook some power to the Porsche and see if everything works!!! Thanks for reminding me about the stock fuel injection power plug.....I'll let you know what happens.....Steve
Quick Reply: Porsche 914 conversion
