912 Forum 1965-1969
eduacate me!! 912vs911
Old 12-03-2006 | 01:14 AM
nine64's Avatar
nine64
Default eduacate me!! 912vs911
so what is the difference between say.. 1968 912 and 911?
i am looking at a 912 with 2.7 carb engine in it.. but i dont know much about early porsche.
cheers!
Old 12-03-2006 | 09:11 AM
Driver8's Avatar
Driver8
The major difference between a 911 and a 912 is the motor. The 911 has a flat 6 cyl while the 912 has a flat 4 cyl. If the car you are looking at has a 2.7L motor, at some point the original one was replaced with a 911 6 cyl motor from a 1973-1977 911. A 912 of that vintage would have had a 1.6L 4 cyl motor. Here is a good resource to learn about 912's
http://www.912registry.org
Old 12-03-2006 | 10:37 AM
nine64's Avatar
nine64
thanks
Old 12-18-2006 | 12:28 PM
Steve Jensen's Avatar
Steve Jensen
Actually it should be a 1720cc motor, not 1600cc.
Old 12-18-2006 | 12:35 PM
Jay Laifman's Avatar
Jay Laifman
1720???
Anyway, there are also other differences that you may want to consider. The front suspension is different, the tranny is different, the rear suspension is different, and the interior is usually different. I don't know if there are any internal structural differences between the bodies themselves. But, some do take 912 bodies and strip them and rebuild them as 911 engined race cars, etc.
Old 12-18-2006 | 01:14 PM
Steve Jensen
Jay - yup, 1720, same size as a "big bore" 356 or a SC motor...
Old 12-18-2006 | 06:51 PM
ked's Avatar
ked
the 1720 is an aftermarket upgrade - the factory delivered the 912s w/ the 1600 (actually, 1582cc) motor, named the 616/36 (or in the case of US in '68, the 616/39). basically much like the 356 1600SC motor (616/16), w/ slightly different heads. the late 356 "Normal" motor is also 1600 in stock form (616/15).
a stock (well, Webers...) '68 912 is sitting in my driveway right now. I don't own it... yet. but it is a light, quick, efficient, great handling car & the swb works just fine w/ the flat four...
Old 12-18-2006 | 07:44 PM
hoffman912's Avatar
hoffman912
The Hoffinator
No, a 1600cc is stock and was teh only available size from the factory. 1720 is a big bore kit, which was not available from the factory. most have the bigbore kits now.
Old 12-19-2006 | 11:19 AM
Steve Jensen
Hrm... I thought the difference 'tween a 356 C and SC was the displacement and crank... and hte 912 was a slightly more evolved SC...
I stand corrected.
Quick Reply: eduacate me!! 912vs911
