911 Turbo (930) Forum 1975-1989
My 86 runs rough on cold start, help!
Old 08-03-2014 | 11:51 AM
2qwik4u's Avatar
2qwik4u
Default My 86 runs rough on cold start, help!
It will eventually shut off unless I play with the throttle. Once its warms up it runs like a top, but I would like to just start her up and drive away. After doing a few searches here on the topic it seems as though the most common problem is the isv or iac valve(I'm assuming its same part) and the temp 2 sensor. Can someone advise exactly where these parts are located, please be specific as i am not that mechanically inclined. Would also like part numbers if possible.
TIA
Old 08-03-2014 | 12:07 PM
theporscheguy's Avatar
theporscheguy
My '86 911 ran rough after warm up which turned out to be the 02 sensor. I've heard other people mention the ICV (idle control valve) for cold start issues. You can find the picture of the part on Pelican and you can't miss the location if you open you engine compartment. Right in the middle of the engine toward the top.
Old 08-03-2014 | 12:22 PM
2qwik4u's Avatar
2qwik4u
You mentioned your can ran rough after warmup, that would be the opposite problem I'm having. Once warm she drives great.
Old 08-03-2014 | 10:56 PM
TT Surgeon's Avatar
TT Surgeon
Make sure your warm up regulator is functioning properly.
Old 08-05-2014 | 01:47 AM
mel_t_vin's Avatar
mel_t_vin
Originally Posted by 2qwik4u
After doing a few searches here on the topic it seems as though the most common problem is the isv or iac valve (I'm assuming its same part) and the temp 2 sensor.
I don't believe your car has an actual ISV or IAC.
I would look to the AAR or, as Chris said, the WUR, which controls cold/warm fuel pressures.
Old 08-05-2014 | 01:52 AM
mel_t_vin's Avatar
mel_t_vin
On second thought, your issue could also be due to a faulty CSV [cold start valve], 930.606.107.01, mounted to the back of the intake manifold, right below the throttle body.
Old 08-05-2014 | 11:23 AM
MUSSBERGER's Avatar
MUSSBERGER
uninformed gas bag
(contemplating on whether gas bag is one or two words)
I was under the belief the WUR needs to be adjusted for the ambient temps. If adjusted for cooler weather it runs like crap in warm weather and vice versa.
Old 08-05-2014 | 11:42 AM
TT Surgeon's Avatar
TT Surgeon
^^That's what I was always told as well.
Quick Reply: My 86 runs rough on cold start, help!
