MSD 6al vs MSD 6-BTM
Hi guys..
I need som help to choose which one of this MDS is best to my 930,6-BTM is more to turbo cars but the 6al is more popular to Porsches???My car will not be stock,it will have more hp and so...
Please help me...
Please help me...
The MSD 6-BTM provides for additional ignition retard based on boost pressure and is selectable via a dash mountes switch. Unless you are going to spend time on a dyno tuning it, I think it might get you into more trouble than its worth. You'd end up advancing the distributor which would advance the ignition timing across the range, and then retarding it with the MSD unit. It COULD work, but trying to run a 930 engine near the edge with the CIS and distributor is not all that wise.
The MSD 6A is a straight ignition system swap from the factory box, however, it really isn't all that much of a performance component, so if you are looking for a power improvement from it, I do not think you'll find one. If you factory ignition box is broken, then it make sense. If you are converting your engine to EFI, you'd want the MSD 6A without the integrated rev limiter as it can often cause issues with the ECU.
You should study and consider MSD-6 AL. Fully programmable.
See: http://www.msdignition.com/Products/...ble_6AL-2.aspx
Mark
