Blownsix Design intercooler
Do a seach for B6. While some have had good results, most have not.
I have a Kokeln that I'm happy with. Others mentioned above and maybe B&B (although service with them...).
I have the half bay B6 intercooler mounted in my car and it took quite a bit of "finneggling" to get it to fit right...had to fill in some of the mounting holes on the metal mounting brackets and re-drill them 3/8ths to 1/2 inch off to the side in some cases....it is not a plug and play or "bolt on" as advertised. It takes some futzing around, but once it's mounted, it does a good job. The full bay version fits much better than the half bay....but I wanted to keep my AC unit in the car. The other models mentioned previously are probably a better bolt-on approach that fit without messing around with mounting brackets etc.
