Sanity Check-911 to 930- Headers the same? Seller says they are?
Guys-
I'm not crazy here- I could see the mufflers being the same but the Headers?
I have a set of SSI headers w/ heat off my 80 Euro SC and was planning on getting a set for my 85 Euro 930. I found a used set of headers and a muffler for a 911/930 78-89. I think he is wrong. Can someone enlighten me- do I ALREADY own a set of headers for the 930? I doubt it.....
Mike
Mike
Interesting with the "nice Piece". would it be worth looking into since I already own the SSI 911SC headers, an SSI 991SC muffler and a GHL Stainless 930 Muffler and a GHL Wastegate down pipe.
Maybe Ben can make a sugestion... Thanks in advance- Mike
The SSI heat exchangers for the 930 are not the same as the 911.
The designs are similar in appearance. The primaries come together a bit earlier and are mated to the Y-pipe with V-band connectors. The Y-junction is designed for better flow to the waste gate pipe than others on the market. Probably the most significant difference is the material they are made of - 347 stainless.
You could make a set of N/A exchangers work but it wouldn't be the same.
Here is a picture of the 930 SSI:
