Another rebuild/EFI conversion
#47
Originally Posted by schnele
Hey Olli is the dyno chart reflecting rear wheel HP or Flywheel, the chart indicates the latter. Great numbers either way and done in great time as well.
How's that for a convoluted long answer
The short answer is that it is rear wheel power. Apparently Dynapack removed the word Flywheel in the later versions of the software because it was causing too much confusion.
#48
Originally Posted by 125shifter
It's great to see how well the engine turned out, congrats!!!
I can't to wait to hear about the 6 speeds, both of them .
Once all that is done and I've driven a bit with the G64/51, I will do another post to give my impressions.
BTW another thing I am looking forward to is the sports clutch with the pressure plate and single mass lightweight flywheel that Jean sent with the sequential.
That flywheel should make a difference and of course the sports clutch will be a bit different from what I'm used to. The LWFW/Clutch/PP looks like it's never been used!
#49
Olli the torque numbers are STAGGERING! anything over 500 for torque is nuts. The trans will also move the engine back further which may lead to other issues. Did you have the case and the main shaft machined?
#50
Maybe that has something to do with the torque numbers.
The case and main shaft were not machined. I hope I can get a picture of the installation just before it goes in to show what was done. If I do I will share it.
#51
I wanted to bring this thread to the fore since my car is now at Speedwerks, thanks Olli, I plan to pick it up in a couple of weeks maybe we can rustle up some Rennlisters to meet up a Speedwerks. I will be driving down with a trailer so I am planning to be in the area for at least one full day.
#52
Yes, I think for anyone around here who has not been to Dave's shop yet it would be pretty interesting to see what goes on right here.
Also, I think on the weekend of Sept 7 - 9 there is some event at VIR again. Would be a convenient coincidence if your car was ready at that time. We'd be assured to meet up with some other Rennlisters during that weekend at VIR.
#54
An update on the 6 speed installation: The G64/51 is in the car with the AP Racing lightweight flywheel/PP/Clutch that I received with the sequential. I had a Guard TBD installed in the transmission and SpeedWerks also did some preventive maintenance by putting some new gaskets in there.
A prerequisite was also replacing the torsion bars with full RSRs all around since the torque bar had to be cut due to the length of the box.
Here's a few pictures of the installation:
The RSRs (just showing the rear ones not to waste too much space here):
The G64/51 stamp:
The mount from inside the car:
A couple of pictures from under the car focusing on where the linkage is to the shaft from the shifter:
the drivetrain:
Once the brake lines have been coupled together, the inside cover placed on the part of the transmission that protrudes into the car + carpeting etc., and I am supposed to select a new speedo, I will post my first driving impressions with the 6 speed. Just testing the shifting inside the car feels real good though.
Edit: BTW, no modifications of any kind were made to the transmission itself for fitment. Naturally, the shaft from the shifter needed to be shortened.
The G64/51 stamp:
the drivetrain:
#56
Good stuff Olli, I hope Speedwerks will have both our cars ready soon, looks like you will be first, so you could show me some North Carolina roads when I pick mine up.
#59
Shop Rat
Olli,
What an unbelievable project! Did you perform any chassis/shock mount strengthening for the RSR suspension? Do you have a shot of the shifter mechanism for the sequential box?
Jim
Jim
#60
Thanks Drew and Jim!
Jim, I will have a front strut bar installed and the rear shock towers were strengthened already - can't see it too clearly here but there is some stuff welded on.
If this is not the shot you had in mind, let me know and I can take another picture today since the sequential is in my garage.
