Do I have a bad WUR??????????
car is hard to start, once started will not idle until it is warm. car coughs and sputters and billows smoke (whiteish and dark brown/black)
once warm it seems to run fine but will sometimes cut out under hard acceleration
are these symptoms common with a WUR failure.
I changed the plugs and fuel filter last night but it did not make much of a difference. the car did start a little easier, but not easily.
Sounds like a WUR, but without checking the cold and warm pressures with CIS gauges, it's hard to tell for sure. If you buy a stock WUR, be sure and buy a new one not rebuild. Somebody's making an adjustable one if you're into tinkering.
What year is your car? Also, a faulty cold start valve could cause probelms. You really need the CIS pressure gauges to determine the WUR health. Here's a thread that I started about my issues with the WUR. I've also documented where I got my gauge set. So far, I have used the gauges on numerous occaisions...so it was money well spent.
https://rennlist.com/forums/911-turbo-930-forum/297546-a-crazy-little-thing-called-a-wur-warm-up-regulator.html
Don't buy a new WUR...there are places that can offer a rebuild. The Brian Leaske (FLYN930) WUR would be the best option and it would be completely adjustable!
Put a meter across the electrical terminals, if you get a resistance then your WUR can be rebuilt. If there is no resistance then it is junk, a new or secondhand one will have to be replace it.
sandman
the car is a 1986.
i also have one other question. the car has been desmogged by a previous owner and it apperars that the o2 sensor is unplugged. this is a wire that leaves the left rear of the car and goes directly to the exhaust. should this be unplugged if the car has been desmogged?
thanks,
Leslie
the car is a 1986.
thanks,
Leslie
Originally Posted by hailwood
sandman
the car is a 1986.
thanks,
Leslie
the car is a 1986.
thanks,
Leslie
I still you think you ought to do some more digging. There are lot's of things that go wrong with CIS. It could be the WUR - it might be something else...I'd have it checked before sinking some bucks into it.
hey just a FYI. i did some searching on the bosch site and found the part number for the WUR. i also found out the napa, vip and robbins(local) auto sell them. as well as a lot of other fuel injection parts for our cars. napas price is.......a heck of a deal. they also sell the cold start valve, injectors, oil filters, rotors, pads and a lot more.
Product Name NAPA Part # Non NAPA Part# Price Select
Warm-Up Regulator - Remfd CRB
217823 0438140153 $244.00
Core $27.75
here are some more bosch numbers i thought you might be interested in. napa sell all of them.
Part Number Description Where To Buy
0 280 140 204 Auxiliary Air Valve Locate Retailer
0 438 120 205 Air Flow Sensor Locate Retailer
0 280 170 400 Cold Start Valve Locate Retailer
0 438 170 031 Fuel Accumulator Locate Retailer
0 438 100 145 Fuel Distributor - New Locate Retailer
0 986 438 145 Fuel Distributor - Exchange Locate Retailer
0 280 160 302 Vacuum Limiter Locate Retailer
0 437 502 017 Injection Valve Locate Retailer
0 280 161 019 Pressure Damper Locate Retailer
0 280 120 107 Throttle Switch Locate Retailer
0 438 140 153 Warm-Up Regulator - New Locate Retailer
Core $27.75
