Speedometer signal
Speedometer signal
What kind of signal does the speedo use from the tranny to the gauge? Is it a digital signal (on/off)? I want to feed the signal to my ECU to measure speed and gear selection for boost control.
Thx
Thx
Don, hope this helps.
Note, it is for the 915 from the 3.2 carrera though. It appears it is on - off.
http://www.porscheclubgbforum.com/tm.asp?m=216390
There is a connection in the tunnel under the plate where the coupler is. Use an ohm meter connected to the two wires coming from the sensor. Drive the car or just turn the rear wheels and you should get a reading that moves from continuity to infinite ohms.
The best way is to use an oscilloscope which will show the waveform and you can determine if the wave is a rising or falling wave as well as the number of teeth (I believe there are 6 but cannot remember). A mag wave will be an analog wave, not an on/off digital wave.
My meter auto ranges, but you need to be able to read 0 ohms to infinate ohms. Basically,if you get a reading that flucuates then you can safely assume the sensor is working. Now, if you are trying to check for speedometer accuracy or want to know anything more in depth like how the waveform looks then you need to do what Geoffrey suggests with a scope. For general purposes though, that is not neccessary.
