Widest possible rear rim/tire combo?
i have been told by more than a few places that 315s will fit without rub... not that i really want to run a 315 in the rear.
however i'm getting conflicting info on the wheels, Fikse says i can get a 11.5" wide wheel into the rear without any body work and removing the 1" factory rear spacer. But Kinesis says a 11" rear is the biggest...
also, we have the 993 Big rears front and rear if that will make much of a difference.
nobody seems to be able to give me a definative answer, what is everyone on here running as far as widths and offsets go?
TIA
TIA
If you're looking at the 315 tire, I'd go with a 11.5 rather than 11". Unless you find a super good deal on some 11", in which case they should work just fine.
This question cannot be answered so easily. There is a relationship between wheel width and tire width/hieght to be considered. A narrow wheel will pull in a wide tire and a wide wheel will stretch a narrow tire.
You have to work with wheel well width and hieght (from the ground). For most widebodies that number is 13.5" +/- 0.5". On my Euro hieght car I can run 345/35-15s on 12x15 wheels with the available space maxed out. Rubs very slightly when auto-Xing. Currently I have 315/30-18s on 11x18 wheels and they look lost in the well. A good 18" fit would be 335/30-18s on 12" wide rims.
Using 2" spacers in the rear I have 7.5" of back spacing.
Anyone have any pics? Eventually I'd like to convert to turbo flares. I wasn't aware you could fit up to 335's under the stock flares.
How about the fronts? I've seen a few running anywhere from 255's to 265's in the front. Wow, the stock Carrera front wheel wells don't seem to have ANY room for tires. I had 245's up front but, they rubbed bad and stuck out .5". Hehe, the 205's I have up front now just don't cut it.
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
I read somewhere that the oil lines will rub a 12" wide wheel on the right passenger rear wheel well.
anyone know if the old school Gotti's rub these lines? Reason is Im thinking of picking up a set.
thnx
thnx
The 345s will rub the oil lines and the suspension adjustments bolts. You have to move the lines down and shave the bolts. No big deal.
Here's a pic of the 15's - 255/45 front, 345/35 rear:
Below that is a pic with the 18's - 255/35 front, 315/30 rear:
We are going to run the Pirelli P-Zero Corsa Systems as i get a great price on them.
235/40/18 front on an 18x8.5 or 18x9" rim
either 295/30/18 or a 315/30/18 rear on a 11.5" rim.
i'm trying to shave as much caliper padding off the rear setup to get the maximum amount of dish possible. Fikse is just a couple hours away so i could drive down and get fitted to exactly what i want but i REALLY like the K18Rs!
i probably should just get off my butt and measure it myself.
just wondering if anyone has already done the measurements on this sort of setup and hasn't posted....
Location: Waiting for the pass behind you, or Sebastopol, CA
CCW built me 18's, 9 and 12's for the track. Your basic steamrollers.
Running 245/30 and 305/30 Hoosiers, no factory rear spacer.
I too wanted 315's and will try them next, just wasn't sure they'd fit.
The passenger side rear did initially rub on the oil line. I couldn't adjust the line enough, so I use a 1/4" spacer to kick out the wheel. No problem. Clearance wise, I think the 315's will work in the fenders.
You can never have too much tire in the rear with these guys; less chance the rear will be leading you off the track.
Cheers -
Glenn
Cheers -
Glenn
Are any of you guys running 315s on a 18" wheel concerned with weight at all?
RarlyL8 - Your car looks MUCH better with the 18s than those 15s
Yasin
Yasin
