Widest possible rear rim/tire combo?
#32
Slumming? That's a good one! Some of the 930s on this board have engines worth more than my car!
Here is my old '73 with 930 flairs. Same 9&12x15 wheels with 345 rears. You can stuff a lot of tire under these cars with just a few easy mods.
#33
[QUOTE=ZX3tuning]Garen,
great looking wheel! Great looking car too!
do you happen to know what the offset and back spacing is on those?
How much dish do you have in the rear?
do you have the space for the extra .5" combind if you cut a little extra the caliper padding off the rear and shifted the back spacing in a bit more?/QUOTE]
Have a look at this image, I have combined some wheel specs for both front and rear on the same diagram. I will measure tire to wheel lip clearances this weekend and post the results. As for the inside, I'll do my best, since you really want the suspension to be at ride height when you measure.
-Garen
-Garen
#34
Originally Posted by odellconsult
Garen -
From where did you get your center caps? They complete the wheels nicely.
Glenn
Glenn
The center caps are from CCW. They are only available when you get the "street" wheels, and are installed from the backside of the wheel. The cap gets sandwiched between the wheel and the hub, and can only be removed when the wheel itself is removed. They are also what makes the wheels hub-centric. The "track" model wheel, which is I think what you have, is lighter, as it has more weight reducing measures such as extra holes on the outer perimiter, as well as extra holes around the lugs, and no center caps. I just liked the clean look of the "street" model, and decided against the weight savings. This was a sacrifice purely for looks... The track wheels do look cool on your ride. The car looks ready to eat-up the track.
Fast82930, that is one sweet ride. I love the stance.
-Garen
#36
Location: Waiting for the pass behind you, or Sebastopol, CA
Garen,
Thanks! I don't have an eye for detail, and missed the now obvious differences in the wheels.
I do have the track version, but didn't know CCW also made a street version. The caps do give them a more finished look.
Fast 82930 - beautiful ride!
Glenn
Glenn
#37
Thanks Glenn, you have a very sweet ride yourself!
As a suplement to Garen's drawing, Fikse has a great Fitment Data Sheet to help determine the proper offsets.
Fitment Data Sheet
Lyall
Fitment Data Sheet
Lyall
#38
Lyall,
great looking car. mind if i ask where you got those bumpers?
I was thinking about doing RUF front lip or even RUF replica bumpers for the widebody but those look very nice and i'm not real big on fibreglass bumpers....
Thanks for the info.
I have the Fikse and Kinesis fitment datasheets, just haven't got the time to measure up the car right now, plus this is a great way to get ideas and pics of what other people are doing....
#40
What are you guys running for tires in 17" / 315 sizes? There seem to be very few choices. The yoko A032Rs seem to be out of production. It seems like Victo Racers maybe the only choice. Maybe there are Sport Cups in that size. I am looking for DOT-R Compounds.
#41
Hoosier has tires in that size as well, but it would barely pass for street use. As for non-DOT-R tires, I think the most aggressive one would be the BF Goodrich G-force KD:
http://www.tirerack.com/tires/tires....Force+T%2FA+KD
-Garen
-Garen
#43
Ok, how does this sound guys...
Removed factory 1" turbo spacer. 18x11.5, 7.6" BackSpacing, 34mm Offset?
305/30/18 Kumho Ecsta V700 tire...
fit without rub or modifaction with a 4" outter lip in the rear?
i'm pulling the rims off this weekend to measure everything to be sure it will clear the calipers... just wanted an option if this MIGHT work.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
