Spark Plugs
Spark Plugs
So sorry guys I know this is a very boring question but I have been doing some reading up. So which spark plugs should we use for a stock 88' 930. Bosch W3DPO, NGK BP8ES, NGK BPR8EIX, NGK 9EV, Bosch W24ES-U, Bosch W24ES-ZU or Denso IW24. Beru ??, Champion??
I don't mind using the conventional plugs but they are not widely available. Seems like dealers mostly carry performance plugs like iridium, platinium, paladium... My concern is these high performance plugs generally are easier to foul due to their small electrode size. Any inputs will be great!
Geoffrey,
Are you saying a W4DPO?
Originally Posted by Geoffrey
I think the 3 is too cold for the 930 and recommend going to a 4. I have had great luck with the W4CS plug which is a silver plug.
Sand_Man,
The BP8ES is a standard plug with the large center electrode. The Electromotive ignition is inductive and requires, if I remember correctly, a 0.024" (maybe even less under high boost) gap due to it's lower output voltage. Usually a low-voltage inductive ignition needs a small center electrode to get decent plug life and help prevent fouling.
When I finally clear a few projects out of the way and finish my XDI installation, I'll be using Denso Iridium plugs.
One thing to also consider, is you are still using CIS which goes fairly rich during the onset of boost, then leans as RPM's increase. This fairly rich area will foul a standard plug pretty quickly. Use your BP8ES plugs for break-in of your new engine, then change to a quality Platinum or Iridium plug.
Win
Win
.024 is the recommended gap from Electromotive on typical 930 applications. Although the power of the wasted spark XDi system is less than a CDI, it is on for a longer period of time per event. So, if you choose the right plugs (resistor, heat range and length), it should work well.
