Symptom of a bad WUR?
I have been experiencing a sputter like occurance in my 930. This only occurs under full boost at and beyond 5k RPM. The car will continue to push forward but it is almost as though the engine is hesitating. It actually almost feels a bit like little back fires similar to the burble or popping that a lot of us hear when you let off the gas.
I just had my modified fuel head installed and the fuel pumps checked so I am at a bit of a loss. ANY suggestions would be very appreciated.
Thanks in advance everyone.
Don -
Exactly, The car runs great up to 5k (even beyond if I am not at full boost), but when I am at 1Bar and reach 5k RPM I start to experience the stutter. Don't really have a good way of measuring fuel pressure, would have to rig something up I suppose.
Could be a pressure leak somewhere, explains why it relates more to boost than rpm.
I had this type of problem many times, don't know the details of the 930 even if it's very close to my car (964 turbo). I would check at high pressure places, between turbo and IC, IC and BOV, IC and throttle house etc.
Rennlist Lifetime Member
Simply hook up a set of CIS gauges. I would go to JC Whitney for a cheap set. You simply need about a 9 bar gauge and the fittings. Any CIS tester fro BMW, Audi, VW etc will be ok.
The WUR does control pressure through the range, but I think it's more prone to adversly affect the cold pressure. I would guess a bad pump, fuel filter, or ignition.
The WUR also has a boost circuit that dumps pressure under boost.
I had a similar problem last year. thought it was a fuel problem. ...ended up being plugs!! totally amazed me. now I change my plugs after every race weekend.
Yes, depending on the head it will drop 2 bar to enrich the circuit. This is why you see the big AFR dump at first on the dyno then it leans towards the top.
