Result of running lean under high rpm/ 1 bar boost
Hi@all,
just wanted to share the results of a little race on the german autobahn between my 930 (Kokeln IC, K27, GHL headers, Mille Miglia Exhaust, 1 bar boost spring, Tial wastegate) and a SL 55 AMG:
I won and accelarated him out completelly revving each gear over the redline, only wondering that in 4th gear I was not able to rev over 7000. Afterwards I was driving at mid speed (about 200-210 Km/h) and mid rpm for about 20 min when suddenly a big bang stopped me. Leaving the autobahn and looking under the car I saw steam coming out under high pressure between head and cylinder no.3.
This weekend we took care of the engine and you can see the results on the photos: Typical signs of uncontrolled detonation on piston no.3 and a bullet hole in head and cylinder no.3.
Also detonation marks on piston no. 1 and beginning marks on piston no. 5 and 6.
The mechanical stuff should be fixed in a week, but what I want to cure is the problem of running lean at high rpms under 1+ bar of boost.
Is a fuel enrichment system like the Andial a proper way to go or are there other solutions to solve this problem?
What would the experts suggets?
Thanks and Greetings from Germany
Stefan
Stefan
Stefan...tutt....tutt....not good...but you have the right attitude. Heat is always the enemy!! I hope next time around you invest (cheap to buy now) into a good wideband and do some extensive testing and data logging before racing those pesky AMGs.
Forget the Andial Fuel enrichment, you need to have your fuel head modified for more flow two people that can do this:
1) Stephen at Imagine Auto
2) Steve at Rennsport Systems
Both are in the U.S but I am sure they can turn this around quickly for you.
Regards and good luck - Yasin
I would also check the injectors to see if they are flowing at the same rates across all cylinders. Number 3 cylinder is definitely running leaner than #2.
If you are running near 1 bar boost, you should strongly consider a twin-plug setup.
Hi@all,
at first thanks alot for the good feedback that leads me into a good direction.
Very good timing indeed that the latest thread exactly discusses the proper topic - fuel head modification.
As far as I have learned till now this might be the best way to start, but cleaning the injectors in addition is also mandatory before rolling road the car.
I will give stephan at imagine a pn to discuss further steps.
Cheers and thanks again
Stefan
Stefan
I don't think a Euro fuel head flows enough for continuous high speed running with those mods. Optimum would be EFI, then Imagine Auto's fuel head, and then the Andial set up.
The PO of my car did something like this happen at a DE, he went with the Andial set up after his engine was rebuilt. I still have the Andial fuel enrichment if someone wants to buy it.
I dissagree on the euro fuel head comment. Mine produces plenty of fuel as shown on a dyno.
What's your AFR at full boost and high RPM?
Interesting point, but how would you know either way to suggest that the engine is not getting enough fuel at such times? You can also emphatically state beyond all doubt that our cars run lean at 500 feet elevation when ambient temps are 85 degrees and the relative humidity is 82 and when following a Cayenne, but that doesn't mean it is right.
I think to suggest that the fuel delivery tapers off over time is a bit suspect.
You can't much do a track run with a quality AF gauge hooked up, and the small cheap ones that some people put in there cockpits aren't of much use. The only reliable or controllable method is to test on a dyno.
That said, our CIS based cars are all engineered with a slide rule. There are variations from unit to unit on how much they can flow. Some are good up to 430hp while others are show to be good to 470hp.
