911 Turbo (930) Forum 1975-1989
Can you run 3.6L 964 turbo P&C's on 3.3?
Old 10-04-2005 | 06:41 PM
JoeMag's Avatar
JoeMag
Default Can you run 3.6L 964 turbo P&C's on 3.3?
Can 3.6L 964 turbo P&C's be run on 3.3L heads, etc?
If so, could they be run with CIS?
Old 10-04-2005 | 09:24 PM
Geoffrey's Avatar
Geoffrey
The head stud spacing is different between the 3.6 and 3.3l engines, so no.
Old 10-05-2005 | 03:13 AM
ProtoCab's Avatar
ProtoCab
The biggest you can go with the 3.3L is 3.5L I believe, but this requires machining of the case spigots.
Old 10-05-2005 | 03:33 AM
Sameer's Avatar
Sameer
Yes you have to machine the case spigots which some do not recommend
Old 10-05-2005 | 12:53 PM
edpurplett's Avatar
edpurplett
I do believe there are now 3.5 'slip-ins' for the 3.2/3.3 cases..
Old 10-05-2005 | 12:58 PM
Sameer's Avatar
Sameer
edpurplett,
where did you hear that from?
Old 10-05-2005 | 02:50 PM
Rob S's Avatar
Rob S
There's an interesting and relevant thread over on Pelican:
http://forums.pelicanparts.com/showt...53#post2159553
According to Henry Schmidt, it's possible to achieve approximately 3.5 liters by using a 3.6 case, 3.6 n/a pistons machined to a custom comp ratio, a 3.3 crank, and 3.3 heads machined for different stud spacing. Sounds like an interesting and potentially robust way to bump displacement compared to the 100 mm p/cs shoehorned into a 3.3 case. And per his post, he'll do that mod for *the same price* as the cost of new 3.4 p/cs (which is up to about $4600). That means that used 3.6 parts must be relatively inexpensive, which was also something I didn't know. It occurred to me that if this idea was coupled with Nickies or JB Racing's iron/alum cylinders, you may have yet another opportunity to ceremonially squander your hard earned dollars in the quest for a big displacement and high horsepower.
Old 10-05-2005 | 04:17 PM
edpurplett's Avatar
edpurplett
Sameer,
I know people have been using the 100mm jugs for quite a while.. I believe initially it involved case work, but I assume Mahle changed machiing and they drop-in now. . not sure.. I personally would prefer a 3.4 or 3.3.. stronger and better sealing... (right Geoff :-)..).. if its a big deal I can confirm...
e
Old 10-05-2005 | 04:58 PM
Geoffrey's Avatar
Geoffrey
Ed, it is true I prefer the 98 over 100mm P&Cs due to the sealing surfaces compromize that needs to be made when using the 100mm "3.5l" P&C kit.
Quick Reply: Can you run 3.6L 964 turbo P&C's on 3.3?
