Oil cooler question
Oil cooler question
I have an 84 930 that I plan to do some drivers ed events with car is in excellent shape but I have been getting mixed answers, Do I need an additional oil cooler(front mount) to keep this car cool, The sessions are 4 to 5 30 min sessions a day, any help will be usefull as I am new to the TURBO CAR
Jason
Jason
I have the OEM fendor cooler with the fan and run find the car runs too hot at the track. I just dropped mine off at my mechanic to have the Ruf front mount and lover valence installed. If nothing else... consider it money well spent on an insurance policy on a motor that is very suseptable (sp) to ALOT of heat.
With a large center mounted oil cooler, you should see temps less than 210F at the peak of summer while on the track. Without, you'll see over 240F on an average day
I agree on the Ruf front mounted oil cooler for altimate cooling and it looks great!
If you are wanting to retain the stock look I know of a couple of shops that will install an additional stock oil cooler in left fender well. It takes a little work to set it in there just right but works well and appears stock. It is probably enough cooling for drivers ed.
Mark Pladson
86 Ruf BTR
(now you know what oil cooler I have)
Mark Pladson
86 Ruf BTR
