Best Replacement Shocks?
John, do you have any suspension mods? Bilsteins are your only choice unless you get into coil-overs. I've had many combos over the years with different torsion bar combos. The simple way is to use HD's in the front and Sports in the rear. I personally found the Sports uncomfortable for use in the front. When I upgraded to larger torsion bars I found the HD's had insufficient rebound and went with custom valved bilsteins all around. The difference is very satisfying. You can get custom-valved shocks for about the same price and the guy I used, Jae at Mirage Intl, provided them on exchange of my cores. You can also get them from SteveW@Rennsportsystems. Each will have their own proprietary specs.
Shop Rat
Has anyone tried the Koni adjustables for front and rear? And would these be a good choice for someone staying with stock t-bars but may go to thicker bars in the future?
http://www.pelicanparts.com/catalog/..._pg1.htm#item1
My impression was that most 930's came with Bilsteins, except for early cars maybe. I did use the Koni Sports in the rear to get some adjustability.
Shop Rat
Pelican has them, but it depends on what strut you have. Some where made for Koni's, Boge's and other Bilsteins. Looks like the Koni's and Boges are interchangeable, but not the Bilstein's. Green struts are Bilsteins. Sorry if I'm giving you info you already know.
I've heard of people using the Koni's for the rears too. It looks like Pelican offers them in front too- anyone use them all around?
John,
Did you get another 930?
Jim
Jim
Shop Rat
I think I'll go with Bilstein HD's in front and Sports on the rear.
I did'nt understand the strut design was exclusive to Bilstein.
That's what I did. Another alternative would be to call Steve Weiner and get with him to revalve you current Bilsteins to work with your torsion bars and sway bars if you upgrade them.
Nope- I did'nt know that. Thanks.
