Whats the cost to twin plug?
Just wondering what the cost is to twin plug an 87 930?
What all is involved and who would you recommend to do it?
Thanks guys
Thanks guys
RL Technical Advisor
Rennlist Lifetime Member
That's right, how else could I give the warranties I do on the motors without all the safety checks in place. I have pulled so many motors apart that I could tell you if a car was twin plugged or not based on the burn pattern on the piston. If you saw the pattern of one then the stock pattern you would be very clear what the benefits are. Not a cheap route by any means, but then again neither is rebuilding a new motor
No doubt that twin plug is good stuff, as you know I didn't stray from the original P's and C's stock spec. and there haven't been any reports of any real design issues if you stay single plug so I didn't twin plug. You do alot of 3.4 motors even though you still twin plug 3.3's.
Boost is boost and pressure is still pressure. The efficiency of the chamber is not changed regardless of 3.4 or 3.3. The valve pockets and the placement of the plug will never provide a proper burn in the chamber. It isn't so much an issue of 3.3 to 3.4. It is an issue of pushing the car harder. Anytime you add HP and timing, boost etc you only increase the heat and burn deficiency in the chamber.
Signed "Mr TwinPlug" LOL
I'm sure Porsche didn't twinplug for the same reason they otherwise inexplicably stayed with CIS on the 930 from 1975-1994, over which time the whole rest of the world went to far more sophisticated and precise fuel systems--cost.
This business I often hear about "if it's so great, why didn't Porsche do it originally" completely misses the unavoidable fact that Porsche, for all its technical skills, was subject to the same market forces and pressures as any other company, and chose on occasion NOT to do what was best, but instead what was cheaper. CIS, especially from the mid-80's on, is a classic example of this phenomenon. And so is twin-plugging.
Exactly Bruce. Why would Porsche do it Brent? They turned the boost down and placed a shroud on the InterC and called it a day. Fat AFRs, made good power and hit emissions. The day was done. When they needed it they did it. I do feel that any car that heads down a path of modifications in the internal sense can benefit and should have twin plugs
Mr. Twin plug
Mr. Twin plug
The 934 was CIS and single plug (probably a requirement) and the 935 was MFI and dual plug. The 935 engine produced about 300 more hp (not all because of the dual plug of course).
The decision to dual plug or not (or any mod) really comes down to what the goals are for your car, where and how are you going to drive it. Do you expect your spouse to ever ride along. yada yada yada.
It always gives you bragging rights at the club DE's
