Oil in the air filter housing / intake
I am working on reviving a 1976 911 with an 83 SC motor, and it is somehow pumping oil into the air filter housing. After a 10 mile test drive, there was maybe half a cup full of oil in the housing What is the likely cause of this?
Crankcase pressure too high?
Oil level too high?
Some kind of valve failure?
Oil level too high?
I haven't replaced those hoses. This car has been dormant for a long time and I have just fired it up. I replaced wiring, service items and fuel hoses.
I usually work on water cooled Porsches and haven't worked on a 83 before so not familiar with the oil plumbing or how oil could get from the crankcase up to the air intake.
Team Owner
Sure sign of massively overfilled
You didn't add any oil by chance did you ?
Did you know there is a special procedure for checking oil.
Has to be done with car running warmed up on level ground.
No, I haven't checked the oil level. It was filled by the previous owner of the car just before I got it. I will check it tomorrow and look for oil breather restrictors, thanks
I haddah Google dat
If it were my car, I'd drain all of the oil and start over.
Spot on, it was 2 quarts overfilled. I left it idling at operating temperature on level ground and pumped it out via the oil tank until it read just below Max on the dipstick. I'll take it for a test drive and see if the issue returns.
I haddah Google dat
^ That's correct. 180F I believe is the operating temp, but if you get the engine hotter, say over 200F then the thermostat will open all the way, and you'll see the oil level actually rise. This is actually the best temperature to drain the oil too, because you'll get a ton more oil out of the tank.
They say the correct way to check oil is on level ground, after the engine has idled for a bit at operating temperature. Carry at least 1 quart with you in the trunk.
