brake
brake
I have heard that Porsche which are equipped with ABS uses black- white configuration system for brake .. Have any idea if it is Cayenne, what sequence we should use for brake fluid bleeding process. What i prefer is RL-RR-FL-FR, does it affect anyway?
R= rear
F= front
L= left
R=right
R= rear
F= front
L= left
R=right
Sometimes with ABS I think there can be special bleeding procedures. You might need to connect up a scan tool to cycle the ABS through the different channels to get all the air out.
Don't know if Porsche has a special procedure or not. This is the early air-cooled section, our cars don't have ABS.
Mark
Mark
Team Owner
R= rear
F= front
L= left
R=right
R= rear
F= front
L= left
R=right
