Leaking hose
I haddah Google dat
okay to back up . I think The elephant racing nut is when you cut off the old nut so a couple points here.
The nut is designed for if you are going to use the old line . in this case he is not so is irrelevant.
Rusnak the nut as above will not help you I don't think if you destroy the stat . you cut of the nut to protect the threads stat, then use the new nut.
I just did this whole thing and feel stupid I did not take pics.
http://www.automotion.com/oil-thermo...1976-1989.html
Could have been TechArt. Not sure.
I just replaced the two oil lines leading to and from the external thermostat. The shop that sold me the lines told me that if I strip the thermostat they have the fittings to fix it. If you strip your thermostat send me a PM and I'll hook you up.
EDIT: I think Rusnak is talking about the same thing.
