I noticed a small drop of oil under the left rear side of my engine. After the shock and disbelief, I crawled under and found that about three of the bolts on the valve cover had a little bit of oil on them. Not a whole bunch, but enough to see and get my finger dirty.
Has anyone else had this problem, and if so, do you know the time and expense involved? Is it just a gasket or and I looking at something more?
You have an early car? They have magnesium covers that mismatch in CTE with the heads. If you change to later aluminum covers, it will help prevent leaks. I have seen this referred to as the 'turbo valve cover conversion' before, I think in Dempsey's 101 project book.
Chris - this is very normal. Just about any 80s 911 will have a little oil leak through at the lower valve cover studs. Usually it bakes off or blows off, but if you let the car sit in the same spot at idle for a while some oil may hit the ground. Usually you can fix this by replacing the valve cover gaskets and nylock nuts. A new gasket and nut kit is about $25 (including the upper cover pieces as well). You can change the gaskets without draining the oil but be preapared to have some spill out. I would first get a torque wrench and check that the nuts are all correctly torqued. I Believe you want 6 ft. lbs. or so.
you can hold them together, mating surfaces together and hold at one end to see if they are slightly warped. also paint the mating surface before you block sand. if you have any low spots they will show up, or spend $40 at a machine shop and have them decked. but they all seem to leak at the studs regardless even with new nylocks, last one i did was a 930 that had persistent leaks on both lowers and I had resealed them a couple times before, this time I tried a little silicone gasket goop on the studs and havent seen it come back yet.
I have an 80 SC. When the valve cover gasket leaks oil, it winds up on the cat, and make s bad smoke!
Now when I bought car it has a test pipe, I put on a cat, it there a shield betwween the cat and the valvecover??
