911 Forum 1964-1989
Steering wheel removal
Old Jul 29, 2003 | 09:32 PM
SPDRacer's Avatar
SPDRacer
Unhappy Steering wheel removal
I am in the process of removing my steering wheel on my early 911
I'm stuck after removing the rubber part of the horn pad. Please help
Old Jul 29, 2003 | 11:43 PM
ron mcatee's Avatar
ron mcatee
SPD, then you remove the large nut and lift the wheel off the steering column. Very straight forward process.
Old Jul 30, 2003 | 02:37 AM
SPDRacer's Avatar
SPDRacer
Angry still problems
I understand that part. but I can't get the metal part of the horn button off of the wheel to get it out of my way to get to that nut. Do I just pry it off, or is there some other trick?
Old Jul 30, 2003 | 10:32 AM
ron mcatee's Avatar
ron mcatee
If it is a 4 spoke wheel, I think you have to rotate the horn button counter clockwise while pushing down slightly on the horn. I believe it is one where there are blades that rotate under a fixed mount.
Old Jul 30, 2003 | 07:45 PM
SPDRacer's Avatar
SPDRacer
Thats what it needed thanks spider
Old Jul 31, 2003 | 02:37 PM
rich 36's Avatar
rich 36
Registered User
Battery off first!
Old Jul 31, 2003 | 05:28 PM
Alan Herod's Avatar
Alan Herod
Lifetime Member
air impact works best on that center nut -- or else be careful for your windshield.
Old Jul 31, 2003 | 09:04 PM
SPDRacer's Avatar
SPDRacer
Thanks very much, I decided to jimmy rig a socket wrench and use a metal broom handle to get the torque that I needed. Beside a few wiring problems (it kept honking), it was fairly easy.
Thanks all for the help
