Question...door weight
I'm going to remove my drivers door to replace the hinge bushings and fix the door stop area.
Does anyone know what the approx. door weight is? '83 911 SC.
No helper...I'm making a padded wooden cradle that will bolt to my floor jack and the door will be 'in place' prior to removing the bolts.
Just wanted a round figure for planning purposes.
I've bolted a 3 ft. 4x4 to my hyd floor jack that has 2x4's attached (think inverted saw horse that fits the door width) and I'll pad that with foam.
Slide it in place and unbolt the door...never have to lift it.
The outer skin/lip hangs over the edge of the 4x4 with shims underneath as the bottom of the door is not flat. This after all of the door stuff is off and wires out.
