Mysterious clicking noise---Help!
My 1984 911 has recently developed a mysterious clicking noise. Can anyone help with a diagnosis idea? I sent this video to my mechanic who is stumped. The noise is intermittent, changes cadence with the speed of the car, sometimes goes away when the car is taken out of gear at speed and sometimes does not. It is coming from the rear of the car.
Here is a link to the video, any help will be very much appreciated!!!
-edit-sorry for the size of the car pics, newbie mistake!
I know I am supposed to post some images of the car so that's what I tried to do, next time I'll resize them first.
Thanks again.
Thanks again.
def mechanical... I would start pulling on anything.... sway bars, cv joints, tie rods, lug nuts, loos nuts and bolts in the engine bay... in other words, something is loose.
Yes looks like dirt/dust buildup in the CV joint. Guess I need to stay off the dirt roads.
Injected some grease in the boot and it quieted right up.
Thanks for the help all.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Kidding.
Let's not stop at grease. The joint is trying to tell you something. It is time to replace if it is making noise.
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
RL Technical Advisor
The other question I have is how the heck did he add a squirt of grease to a sealed boot?
OP, please don't mind my rude questions, I really enjoy cars way more than I should. I've had an affinity for all things mechanical since I was a toddler.
Yes, this is just a glimpse into my tool box. This is my Metric Socket drawer. The second drawer is just as crazy.
Oh, and knowledge is your best tool.
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
Thanks guys,
Knowledge is definitely the best tool and one that I don't have much of-which is why I came here.
The answer to the grease access to the sealed boot question (and how the dirt got in there in the first place) is they are vented boots apparently to help disperse heat from the LSD. If that sounds ignorant, I am repeating the words of my mechanic who has worked on the car for the last 14 years including two previous owners. I will have him pull the CV joints and see about either cleaning/repacking or replacing the axle assembly as needed soon.
My caveat: I have been mechanically declined most of my life and have only recently gotten comfortable being inside machines because for the last two years I have owned a 50 year old Triumph Bonneville that demands my care. The Porsche still feels a little intimidating and anything beyond changing my oil I have left to the professionals.
Team Owner
The Porsche is actually easy to fix so don't sweat it. It will come with time.
Many cv joints aren't sealed at the small end so often a squirting will fix the noise . The problem is though if it's clicking you are likely too late and have worn through the polished surface into the casting.
Replacing a cv joint is easy if not messy. If you are unsure just replace the half shaft and bolts. Then retourq at 500, 1000, 3000 miles.
Good luck.
Good luck.
