if you were stranded??? parts?? relays??
i have had a couple very dependable sc 3.0 911's in the last couple years and they have never left me stranded. so i dont know by experience. it would be a little unsettling if i had to leave one of my babies along side the road. if a guy was to put together a limp home widget kit, mainly engine and electrical related, what would you have?? (pending nothing major, that you couldnt fix along the road). i was thinking along with some tools,possibly an xtra fuel pump and filter. i guess where i'm lost, is there some certain relays,parts,specialty tools that you should carry just in case? if you have any ideas or experiences please share them. thanks
A extra J-Pipe would be good too because this is the achilles heel of the 911. The J-pipe is the oil tube that is right in the throwing path of the passenger side rear tire. If anything of any mass is thrown up in this area or if you run over anything the rubber pipe can be severed and ALL oil can be loss. This pipe tends to get hard too due to heat causing it to be brittle.
Extra fuses, relays (headlight and fuel)
Just my 1/50th of a dollar,
--Brian
--Brian
Technical Specialist
Lifetime Member
Lifetime Member
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica"><strong>A extra J-Pipe would be good too </strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Or you can inspect it on a periodic basis and change it when it starts to harden or crack. I think I changed mine twice in the 5 years I had my SC.
1 Post
among the items I'm carrying on Big Rides are
-various nuts and bolts
-CV bolts
-cap and rotor
-Relays
-points w/feeler ga.
-mirror to windshield stickers
-fuses
-clutch pedal pin
-clutch cable
-oil drain 0-rings
-dash bulbs
-0-rings for tensioner oil feed and oil feel hard lines
-head lite sw.
-ignition sw.
-oil psi sender
-tie wraps
-flat tire fix kit
-CV boot
-coil and CDI
-spring plate toe and camber adj. bolts and nuts
-fuel filter
-air box straps
-spark plug wire connectors
-alternator regulator
-clutch cable
-Haynes repair manual and Bentley manual
-fuel tank screen remover tool
-spark plugs
-torqe wrench and soft socket[check lug nuts every 3k miles]
-test lite and VOM
-full roll of 12ga. black and red wire
-one 5lb dry chem. extinguisher in lugg. comp and 5lb halon in cabin
-emergency road flares
-head lit bulbs
-valve adj. tool and valve cover gaskets
-silicone gasket maker
-lug nuts
-oil filter
-windshield breakage insurance
-Valentine 1 and Uniden Beartracker BCT-7 and CB radio
-leave wheel center caps home
-head lite bulbs
-head lite lens plastic protectors
-flashlites
-bra
-tire gauge
-cell phone
-red pepper defense spray [med size not small]
-2X4 wood for wheels/
tow truck to prevent val. damage
-alarm system pager and Clifford Black Jax type system
-cheap tools[Harbor Freight full set about $150]
-photostat in glove of entering luggage comp. w/broken cable [in Bentley]
-small string to enter fuel tank fill w/broken door cable
-----ALSO, when in hick towns do 5mph less than speed limit if alone on road....watch local traffic for road culture...speed traps are usually within 10 miles of hick towns...never be "point man" in traffic...if big rigs are speed limit + then no bears...if big rigs at speed limit beware...
This is a general list......Ron
-CV bolts
-cap and rotor
-Relays
-fuses
-clutch pedal pin
-clutch cable
-oil drain 0-rings
-dash bulbs
-head lite sw.
-ignition sw.
-oil psi sender
-tie wraps
-flat tire fix kit
-CV boot
-coil and CDI
-fuel filter
-air box straps
-clutch cable
-spark plugs
-test lite and VOM
-head lit bulbs
-lug nuts
-oil filter
-head lite bulbs
-flashlites
-bra
-tire gauge
-cell phone
For a MINIMUM...extra fan belt & tools needed to replace it. Running without a fan belt can cause severe overheating with resultant engine damage right away. The second you lose a fan belt, pull over...
I agree.. except for the clutch cable.
I drove my '74 Int 1/2 ton for at least a month without being able to disengage the clutch.. *laughs*
Not really an "emergency" item..
