911 Forum 1964-1989
1989 911 dashboard clock
Old May 31, 2012 | 04:32 PM
john36's Avatar
john36
8th Gear
Default 1989 911 dashboard clock
This is the last of the old style Carerra's (pre C4).
My dashboard clock suddenly stopped working. I hope it's not the clock (expensive) but just a fuse, but the manual is stupidly uninformative as to which fuse does what. However, I cannot find any other components that aren't working (uh oh!)
Help!
Thanks!
John H
Old May 31, 2012 | 05:37 PM
JABSEA's Avatar
JABSEA
Do you have someone locally that would pop out their clock and hook it into your wires to see if it is the clock or something else?
Old May 31, 2012 | 05:53 PM
1986 Targa's Avatar
1986 Targa
From: Manhattan Beach, California. Retired Engineer 1986 Targa-Factory Delivery Original Owner
Default Capacitors.
Help!
Thanks!
John H
John,
"Assuming" that all of the connections are intact, along with the voltages and grounds, here are the likely suspect:
File Type: jpg
Old May 31, 2012 | 06:01 PM
1986 Targa's Avatar
1986 Targa
Default FUSE.
Originally Posted by 1986 Targa
John,
Also, have a look at this fuse.
Good luck,
Gerry
pm me as needed
File Type: jpg
Old May 31, 2012 | 06:17 PM
dshepp806's Avatar
dshepp806
Should the electrolytics not be the problem,...there are many out there who can repair the clock (not replace it).
Best!
Doyle
Old May 31, 2012 | 08:22 PM
theiceman's Avatar
theiceman
Team Owner
see if you got 12v coming in . if you do its the clock end of .. you could replace the two dielectric caps as they dry out but make sure you get the poles right ..
Old May 31, 2012 | 09:52 PM
dshepp806's Avatar
dshepp806
yeap,..they are polarized, for sure,..you'll know quickly if you f'd up or not !!!!!!!!!!!!!!!! (hehehe)
BEST!
Doyle
Old Jun 1, 2012 | 10:01 AM
TheMystro's Avatar
TheMystro
I love the very accurate dash clock. It's cool looking and another example of German elegance and simplicity engineering.
I hope its just a simple fix. In my experience these clocks are pretty trouble free.
