Dilapidated Porsche worthwhile??
#31
Yes. 1997 S600.
I still think money will be the only thing that beats emotion, but upping your entry cost greatly reduces your ability to have any "fun." Give your friend first right of refusal when you sell it. If you don't plan to sell it, or he doesn't have the money, then bummer.
Brett
Brett
#33
FWIW, I pulled the 911's engine just to replace a broken head stud (actually to replace all the exhaust side studs). Then it became a full top end job, and now is a complete case split rebuild requiring crankshaft regrinding due to wear issues not forseen upon tear-down. It added up very quickly... may be around $5-6000, and that's with used replacement pistons and cylinders and me doing all the labor (but also includes new full clutch kit). Something to ponder as you think about this 1978 911SC that is in much worse condition than mine.
Brett
#34
Yep, drive by wire can be challenging. Had to tear both of mine apart to correct intermittent issues right when I bought the car.....they were totally gummed up and nasty.....haven't had a problem with them since.
I joined this board for a reason and am SO glad I did. All the warnings coming from everyone are certainly making me lean toward finding one in better shape. I have a local guy that only works on air-cooled Porsches keeping his eyes open for me as well.
#35
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Good luck hunting down a 911 or with working over your friend...
Brett
#36
mercedes have a host of electronic issues...can be a bitch... these are cars you have to PPI up and down and all around before purchase!!
#37
My problem started when I took them out to clean them. They weren't really that dirty to begin with, and I wish I had never touched them...
I was replacing the intake boots, one of which had a tear, and thought, "Well, why don't I do something good for the car and clean the throttle bodies." Turned out to be a bad idea.
Brett
Brett
Thanks for the luck! My friend will probably let it rot where it sits unless I hound him....not really my style. Just upsets me to see it go to hell. I remember looking at it as a kid and marveling at how beautiful it was.......shameful to see what it has become.
Cheers!
#38
NO fair saying "well, it's already seen too many"....
#39
#41
Team Owner
Go look for a similar year in better shape and buy it . Then you have the peace of mind of knowing you have a parts donor car just sitting waiting if you need it
#43
At least that's what I'm saying now.......What is the likelihood that the chain tensioners are the originals, or that the Carrera pressure fed update hasn't been done??
#44
its tough on a car just sitting like that...brakes/seals/etc. ...really ashame nobody took care of it.
but like many have stated the parts along are worth money and personally i would be thinking along those lines as oppossed to doing any sort of restoration on a 911sc car. the numbers just wouldn't make sense i believe even if the guy gave you the car.
i'm always looking around for 911's and i found a nice 79sc w/rebuilt engine for $11.5K that will need a little tlc but solid driver and all there. car is in san francisco area and if you PM me i can discuss it w/you and give you the guys info.
i have no affiliation just found it and emailed the seller to get all the info.
#45
I had the car parked for three weeks while the throttle bodies were out, and when I got back in to test drive, the dash started lighting up like a Christmas tree. ESP fault, ABS fault, SRS fault. WTF. Never had ABS or SRS faults before... Unfortunately, it's rapidly becoming a piece of unsellable ****. I wish I had the space to part it out. Sorry, for rambling on this diversion. Had to vent a bit.
Brett
