How to change Air box cover
I bought the fabspeed unit and cant see how it's possible to release the 2 clips on the farside of the unit! I can't even begin to get my hands back there......
It's tight-you have to get your hands back there...
That Fabspeed part is pretty flimsy, isn't it? If you're running an oiled filter, you'll need to be diligent about cleaning, and do not over-oil. You may've been best served to buy a stock cover and cut it, if you want sound. The stock filter breath pretty darned well.
I bought the K & N filter to compliment the airbox. Tomorrow I am set to get all installed by my mechanic, that I sort of explain in my sig. So, I will simply let him do the air box.
Seems a little flimsy, but it's all about air, so doens't bother me. I can slip my hand, but it's my forearms that get stuck! Down side of being a gym rat! lol
Seriously, Carrera airboxes aren't restrictive, so you'll probably just get to pick up the sound aspect. I did pull mine and go to a cone, but that was really cosmetically driven. Fabspeed has varying reputation for quality in 911 circles.
Parts Specialist
are you thinking the stock box doesnt supply enough air flow? (cuz it does)
just a heads up....before buying "performance" parts...read/search FIRST - I learned this the hard way many times
Parts Specialist
Yea, meanwhile my garage has a pile of parts I am on the fence about. It was suggested I do a baselin.e dyno run before hand, so maybe I will do that first
Don't feel bad I bought the k&n cold air system for the 996 and its a heap of tin crap, researched AFTER and returned it before installing it, no harm in mistakes I hope cuz I make plenty
Nothing wrong on the cat bypass, and a free-flowing muffler, coupled with a proper chip. Not cheap HP per se, but probably the cheapest HP bump on a 3.2. Then, you can spend $10k+ for the next 20-25 HP gain..... I know all too well, but wouldn't change a thing.
Fabspeed air box
Sarge,
Here's how i installed mine three years ago ... clips on top and bottom,i found it was the easiset way to remove and install !
As for the extra HP,who knows,there are a lot of claims ... lol
I've had a K&N filter on my F150 for the last 12 years and i drive on dirt roads with no engine damage,just keep it clean and properly oiled ...
Cheers !
Phil
Cheers !
Phil
Sarge,
Cheers !
Phil
Cheers !
Phil
As far as a chip that somebody asked, it's the one that comes w/ the Fabspeed ECU upgrade and tuned for my mods. I think it's called 911 chips or something like that. All is in the shop right now being installed. I will post pics and sounds of all later. How do I upload a video on here? Can it be as simple as a pic or I have to upload it to a site and then give a URL link?
